I think Morfis wanted the data files, not the log file (or maybe all of the above).
They're all text files - fixed number of columns separated by commas. First line of each file describes the format. For EDACS narrow, the files are named EDACS4##.XXX where "##" is the site number and XXX is any of the following extensions. For EDACS standard the files are named EDACS9##.XXX
SYS - system information; first line of data describes the system; the next two lines are templates for creating a new group or radio. See the GID and RID files for format info.
*Sysid,"Type",Listen,Lockout,Trunked,RGB,"Label",First,Last,Delegate,"Notes"
33,"EDACS96",0,0,0,0x000000,"",20061205071404,20061205071404,0,""
0,0,0,0x000000,"",00000000000000,00000000000000,50,0,""
0,0,0,0x000000,"",00000000000000,00000000000000,0,50,0,""
SIT - site information; we're using the EDACS site # as a system id so it actually appears in the SYS file above, not here.
*Site, Listen, Lockout, Color, "Label", First, Last, "Notes"
0,0,0,0x000000,"",20061205071404,20061205071404,""
HZ - channel information; notice the first column is the site #.
*Site, LCN, Control, Listen, Lockout, Frequency, CTCSS, DCS, "Label", First, Last, Confirmed, Hits, "Notes"
0,0,1,0,0,0,0.0,0,"Control",20061205071404,20061205071404,0,2,""
RID - radio information
*Address, Listen, Lockout, Color, "Label", First, Last, Talkgroup, Rank, "Notes"
12771,0,0,0x000000,"",20061010004535,20061010004553,416,50,""
12773,0,0,0x000000,"",20061010004549,20061010004631,416,50,""
12801,0,0,0x000000,"",20061010004546,20061010004618,586,50,""
12816,0,0,0x000000,"",20061010004540,20061010004635,586,50,""
GID - group information
*Address, Listen, Lockout, Color, "Label", First, Last, Rank, "Notes"
315,0,0,0x000000,"",20061010004530,20061120011714,50,""
316,0,0,0x000000,"",20061010004530,20061120011714,50,""
416,0,0,0x000000,"",20061010004535,20061010004631,50,""
561,0,0,0x000000,"",20061010011826,20061120011713,50,""
562,0,0,0x000000,"",20061010011830,20061120011713,50,""
570,0,0,0x000000,"",20061010011829,20061010011837,50,""
575,0,0,0x000000,"",20061120011258,20061120011713,50,""
586,0,0,0x000000,"",20061010004540,20061010004635,50,""
2026,0,0,0x000000,"",20061120011258,20061120011713,50,""
2029,0,0,0x000000,"",20061120011258,20061120011713,50,""
2035,0,0,0x000000,"",20061010011826,20061010011838,50,""
2046,0,0,0x000000,"",20061010004530,20061120011714,50,""
The PLN and AFS files are not relevant to EDACS.
