editing my file in freescan?
scruggsy
Kings Mountain NC
ok, I've got a decent handle on freescan, just one thing perplexes me! if/when I make changes to my file, like adding a light alert or other minor tweaks I end up uploading the entire file for any little thing I do.
is there a way to quickly add the edit to the 396xt from freescan without uploading the entire file every time?
now it only takes a couple minutes to move the file but still, it seems a bit redundant.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Check the options in the upload screen. You will see you have the option to add or replace only what you want. You do that by checking/unchecking the systems as found in the listing on the left of the form
Be sure to check the correct option for what you want to do....best regards...Mike
W2PMX
Fayetteville NC
Uncheck all the systems, so the only thing you'll be uploading is the settings.
