Ok. Awesome. No, I don’t pick them up in Lac La Biche. I come to Edmonton every night.
You’re mentioning a Unication scanner that has IQ. I thought you Uniden was the only one. Which model of Unication scanner is a good one? And is it better than the Uniden model?
Unication is more of a pager than a scanner but they are working at making it operate more like a scanner. I bought the G4 model (700/800 Mhz) before the SDS 100 came out in May 2018 to handle the Edmonton Simulcast.
There are other Unication models that also include DMR, UHF and VHF. I really prefer the the SDS100 over the G4 because it can do so much more. The G4 can only scan 8 talk groups at a time so Edmonton fire would use about 3 different zones. It doesn't mute a mixed clear and encrypted group like Fire info. Also you can't hold on a talk group. Some of the newer models deal with some of these issues.
Programming with Sentinel is much easier than PPS. I found PPS easier because I have a history of programming commercial trunking radios.
The Unication is also much smaller than the SDS 100.
