I have a local electronics store for small boxes to fit a single FT-240, FT-140 or FT-114A size cores. Here is one I just put together with an FT-140-43 core that will handle about 150 watts with the small box I used. I usually use a small stainless steel wing nut for wire attachment but ran out, so this has a temporary brass thumb nut thing.
For higher power stacking two or three FT-240 size cores I use these boxes available from Homee Depot or Lowes. I think this was a Lowes box on this one. Notice the wire attachment with 12ga Teflon wire, removable link, thimble and cable crimp. Ummm, sexy.
Enjoy the Carlon Junction Box E989NNJ-CAR, gray designed to provide protection against external ice formation, falling dirt, hose-directed water and water entry during prolonged submersion from The Home
www.homedepot.com
For caps you might check eBay for dipped silver mica 100pf in 500 or 1kV depending on power. For two stacked cores use FT-240-61 and for three use FT-240-52.
@prcguy - What is your source for the enclosure box and capacitors? I need to build a 49:1 or 56:1 for an 80-10 myself.
