Electrical issues with my 1001z
billytehbob
Hello everyone,
I have a midland 1001z installed in my Wrangler, 3ft Everhardt antenna, yadda yadda, and as of late, for some reason, my CB Radio just decides when it wants to receive power. Some days it'll switch on just fine, others it won't turn on at all. I don't know how or why it's doing this, but I can't see my wiring to be at fault, my fuse is good, ground is good. I've been thinking that it might be something with the radio itself, but I'm not an expert by any means, so I was hoping maybe somebody has experienced this problem and has a possible fix to it. If need be, I can get it replaced as it is still under warranty, but it would be easier if I could fix it myself.
LtDoc
Oklahoma
Sounds like you have an 'intermittent' somewhere. Just to make sure, check your primary power wiring again. Wiggle stuff, see what happens. An intermittent switch is also a possibility. So eliminating the 'other' possibilities can indicate if that switch is the problem or not. It also is a pretty good reason for sending the thing back for warranty work.
- 'Doc
jackj
NW Ohio
It could be almost anything. Double check your fuse holder and clean the contacts to make sure there isn't any corrosion on them. Replace the fuse (new one with the same rating), I have seen fuses develop cracks in the fuse element that are intermittent. If you have a multimeter then check the voltage at the radio's power connector when the radio won't turn on, if you have voltage then the problem is with the radio. Don't ignore the radio's ground.
Intermittent problems like yours can be VERY hard to find. Good luck.
Daniel_Boone
Banned due to duplicate accounts
Banned
The mountains of Pennsylvania
I don't understand what Receive Power means.
Are you saying that the radio works all the time, but at times there is no audio on your radio or are you saying that sometimes it turns on and you can hear people talking and other times it won't turn on - hence the lights won't burn in the display?
KC4RAF
Davenport,Fl.- home to me and the gators and the s
As others' have posted,
but wiggle the wires around, slowly turn the on/off switch on and slight wiggle it, etc. Good luck in trying to find the problem, it can get rather frustrating. And if you've eliminated all avenue and the problem still there, then LtDoc's advice is last action you have, return it to the dealer. Good luck sir...
billytehbob
Sometimes it'll turn on, everything works, other times there's nothing, it's dead.
I'll double check all of the connections, the fuse, etc. I've only had the radio since January, so it really shouldn't be acting up.
