EM Wave on an antenna analyzer
k7ng
Electronics professional
CN73
I have been buying the EMWave 1/4 wave wideband antennas for almost a year now. Try as they might, my customers have yet to destroy one. They seem to handle tree branch strikes just above the vehicle roof better than Larsen or Maxrad. A sweep of the wideband Maxrad varies hugely from one antenna to the next and one installation to the next, whereas the EMWave and Larsens are more predictable. I have run into one bad EMWave and one bad Larsen, where they just had a poor swept VSWR response that wasn't installation-specific. I got about 5% bad out of the bag when I was using Maxrads.
I have installed well over 100 wideband VHF mobile antennas at my present job...
mrweather
What would make a basic 1/4 wave antenna go bad? It's not like there are fancy coils/matching devices.
nd5y
Wichita Falls, TX
As far as the antenna itself not much can go wrong. Corrosion, electrical contact problems or physical damage is about it.
A lot of other things could make the antenna appear to be bad such as mount problems, coax problems, connector problems, installation problems, mounting location, proximity to other antennas or objects, test equiment used to determine the antenna is "bad", not knowing how to use test equipment, operator error, installer error, probably other things.
k7ng
CN73
The antennas I use are 'wideband' types that are supposed to work over a wider frequency range (lower VSWR, in other words) and kinda sorta claim to be 'no-tune' antennas. I need 151 - 174 MHz if I can get it. All that type of antenna has a matching network in the base. If the coil gets smacked by a tree branch as the vehicle runs up a trail at 35 mph, they often quit working. And for similar reasons even though there's a spring, the springs have a metal braid thru the center that carries the RF, and that corrodes and or fatigues with enough abuse. Plus, I'm on the Oregon coast and even the rain has salt in it.
My antennas are non in an antenna-friendly environment.
nd5y
Wichita Falls, TX
0.1000 inches
I think that's what the Larsen NMOWBQ is.
I have been using a FrankenLarsen for 20 years or so made from a NMOQ base, ferrule/cone from a NMO150 (I think), the 0.1" whip from a NMO220 cut down to 1/4 wave a 146 MHz, and no spring. It dosen't bend like the regular NMOQ 0.049" whip and the bandwidth is a little wider.
12dbsinad
We use the maxrad wideband as well. MWV1322S and MWU4505S (if my memory serves me correct). We've had problems with the coils breaking were the plastic meets the NMO threaded collar. The black plastic is threaded and they usually apply glue. If hit real hard they break at the threads.
I have some EMwave samples, haven't used them yet but they indeed do seem well built.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I can't remember where I posted the photos, but I had a 430-450 colinear NGP base from Maxrad that the glue had failed. I took it apart and posted photos of the guts. I want to say it was in 2017 that I posted the photos.
kayn1n32008
Sector 001
The EMWave wide band 1/4 wave are spec's at less than 1.9:1 over 136-174MHz. Screenshot_20210322-212105_Gallery.jpg
12dbsinad
Sounds like the same issue as well kayn
kayn1n32008
Sector 001
Sounds like it. Sad part is that the antenna was used for the data link for a RTK reference station. Never mounted on a vehicle, just a NMO mount that attaches to a survey rod. So it would be set up at the beginning of the day, then taken down at the end, unless a crew was in the same area, and left it until they were done the job. Definitely not abused.
12dbsinad
Sounds like it. Sad part is that the antenna was used for the data link for RTK reference station
If I remember correctly they have a spring contact tab at this location, and a cap for no GP applications. Certainly the weak spot. The antenna's always tunes well though.
kayn1n32008
Sector 001
Correct.
Found the thread I created with the coil disassembled.
