embeding stream onto wordpress page
Scoop531
Kennett square pa
I'm setting up a personal webpage and would like to use a feed (already have permission and api key)
but if anyone has ever dealt with wordpress they don't let you use iframe codes. Has anyone used wordpress and what plugin or code did you use with your feed.
Depending on the theme you select, you can go to Appearance > Widgets > Custom HTML and past the iframe in there. I was able to successfully get it to show up this way.
can you send me the code you used
I'm not sure which code you're referring to. As far as the iframe code, I used the one provided by broadcastify. You'll need to change the key=xxxxxxx and the feedId=xxxxx for your stream.
Code:
<iframe width="325px" height="245px" src="http://api.broadcastify.com/embed/player/?key=xxxxxxx&feedId=xxxxx&stats=1&as=1&bg=000000&fg=FFFFFF">Your browser does not support iFrames.</iframe>
