prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,771
- Reaction score
- 15,037
Another thing you can try that helps in some cases is a good common mode choke in your feedline where the coax exits the house. If there is any RF interference riding on your coax shield from stuff inside the house to the antenna this can reduce the problem.
I use a different antenna than the OP (ZS6BKW) that has a transition from ladder line to coax using a 1:1 balun. I recently upgraded the 1:1 balun from a very basic unit that probably has poor common mode rejection to one that has well over 30dB rejection over most of the HF range. I could immediately see the improvement in the noise floor on my radio's spectrum display and it's not a subtitle change.
I used to have a continuously varying noise floor over any specific HF band with lots of wide bumps and peaks plus some CW birdies all over the place. The new choke basically flattened out all the wide bumps and peaks to a flat noise floor leaving only some of the CW birdies, meaning much of the junk was traveling up my coax to the antenna. I have a lot of computer stuff near my main HF radio and the feedlines pass right by computers, monitors, routers and lots of switching wall warts. I had no real complaint of my average HF noise floor at home but also had no idea it could be improved this much.
The 1:1 balun I built that reduced my noise is very similar to this one : CMC-230-5K - MyAntennas.com and I did a lot of research and testing with various ferrite cores to try and duplicate the performance.
For lower power operation but still good for legal limit this one is probably the best on the market: CMC-130-3K - MyAntennas.com
Its hard to say if one of these would improve your situation but I would recommend borrowing something similar and trying it to see.
prcguy
prcguy
