Equipment that can receive a downlink at 2300 MHz?
lazyfortress
Maryland
Hello, I just got back into SATCOM reception.
My current scanner, a PRO-649, can only reach 800.000 MHz. I have a yagi that is configured for the 120 MHz - 137 MHz range. I'm trying to get a downlink from a decommissioned satellite at about 2300 MHz. What type of receiver can reach up to 2300 MHz / 2.3 GHz? Anything under $300-ish? What type of antenna would be suitable for this task?
Any help is appreciated!
prcguy
Some of the higher end communications receivers like the AOR AR-8200 and 8600 or the Icom R-8600 and a few others will cover your frequency range. Unless there is an SDR dongle that goes to 2.3GHz most receivers will run a bit more than $300. A lot of Wi-Fi antennas will cover 2.3GHz but you will need a large one with some gain and satellite downlinks are usually Right Hand Circular Polarization.
What satellite are you trying to get? I have a big flat panel military antenna from some satellite program that covers a 2.2 to 2.3GHz with RHCP and a receiver that covers that range.
prcguy
lazyfortress
Maryland
I'm trying to get a Nimbus 7 downlink at about 2300 MHz. But now I think it's useless. I need to find out whether Nimbus 7 works or not. I guess right now I want to get a GOES image downlink somewhere at 1600 MHz, along with a few older satellite downlinks at 136-137 MHz.
Grayline
Newnan Georgia
Just a Question? What Are you guys listening to? Is it just Data?
What kind of Satcom Equipment is needed to monitor Satellites?
I have a Data Receiver and a satellite I pulled out of a bank years ago but dont know what it was used for
VK3RX
Thaumaturge
Australia
Post a few pix - someone might recognise the equipment.
The pix of the satellite will be interesting :)
lazyfortress
Maryland
I'm trying to just get raw data from Nimbus 5/6/7 and one of the SOLRAD satellites that's still transmitting. I'm not sure if any of the Nimbus satellites still work. Who would I contact to see if they work, and if I can transmit to them? Would I need a license to transmit to a satellite?
Downlinks of Nimbus satellites are: 136.5 and 136.95 MHz, 1702.5 MHz, 1707.5 MHz, and 2273.5 MHz for Nimbus 7. I dunno how I can receive these downlinks. How would a downconverter work with my 120 MHz-137 MHz configured yagi?
prcguy
You would need a license to transmit to a satellite and the uplinks are probably in a frequency range that you don't have equipment for. What would you want to transmit?
You might be able to find a downconverter that will work with your 120-137Mhz frequency range but your antenna will be useless on the 1700-2300MHz range.
On a similar topic, not sure where you are in MD but I've done some work at the Intelsat Mountainside Teleport near Hagerstown, MD. Look that up if you want to see a lot of satellite antennas.
prcguy
lazyfortress
Maryland
I remember reading in a forum here that you could use old decommissioned satellites for your own use with permission from the owner. What could I do with a decommissioned satellite with fairly simple equipment that is legal? Any ideas? And also, what license would I have to get? A ham license?
prcguy
An amateur will never get any permission to light up a commercial satellite, even if its decommissioned. I have a long carrier in the satellite broadcast industry and have mooched a lot of free satellite time but I or my company was fully licensed for what I uplinked.
One notable time was when I needed a satellite for a little research project and contacted a friend who was in charge of selling time on HSG-1 (later renamed PAS-22), which had failed to reach orbit and was slingshot around the moon and put into a geostationary but severely inclined orbit. I was allowed to uplink to a specific transponder for some research for several days at no cost. This satellite was otherwise operational and its owners were seeking customers with little luck from what I saw.
If anyone were allowed to use a decommissioned satellite, there would be literally thousands of people eager to take advantage of that. It just aint gonna happen.
prcguy
zz0468
Banned
Get your ham license, and you'll be able to use purpose-built amateur radio satellites you are allowed to actually talk through.
lazyfortress
Maryland
Well, darn. I guess I'll stick to regular satellite downlink reception. How can I get the downlink of a satellite with a relatively weak signal, such as SOLRAD 7 I believe? I'm considering getting a BCT15X.
By the way, for all the advice and information everyone!
SteveSimpkin
Lancaster, CA
For reference, more information about Nimbus 7, including some frequencies. It mentions the satellite was turned off in 1995.
https://directory.eoportal.org/web/eoportal/satellite-missions/n/nimbus-7
lazyfortress
Maryland
I still don't get "turned off in 1995". The satellite still has to be transmitting something, especially telemetry. I personally never tried to get a downlink from any of the Nimbus satellites, as my scanner (a PRO-649) is a bit too weak. Hopefully this new BCT15X that I'm considering getting is going to be more "powerful". I have an antenna that is tuned specifically for 137 MHz - 145 MHz, but still works excellent from 120 MHz to 136 MHz.
And I should have no problem getting the downlinks from MILSATs with that frequency list link for the Atlantic.
