Error in IDTRACKER II
mandlair
Hi,all never had a problem with this fine software before today.Tried to start it up today and received this error?ID Tracker II Version: 2.0.2
Module: modIDTracker Routine: Main
Error (429): ActiveX component can't create object Anyone have any ideas? Thanks in advance Mike
brscanning
Baton Rouge, LA
Try reinstalling using the complete setup kit.
mandlair
I tried brscanning,But didnt help so I guess its a problem with microhard to get right ...Oh I mean Microsoft. I'm sure it is a problem with office.....thanks Mike
mandlair
Hi,David I got it going by typing this in the command? regsvr32 scrrun.dll.How do I get it to follow my old files they come up on the logging bottom of screen but not what is in file?comes up as whats on scanner?I which I never had this problem ....lol was set up the way I wanted it now nothing?just shows whats on scanner I set to the files I wanted but still goes to whats on scanner?Oh and also new version wont work at all?Thanks in advance Mike
brscanning
Baton Rouge, LA
So it was the Windows Scripting or more specifically the scripting file system objects causing the problem.
Make sure the "Data Path" in settings is pointing to your old files.
Not sure why that would happen. The latest version was only a minor change. I need some more detail. Do you get any errors?
mandlair
Hi,Dave all going good again except new version I get make sure cc dump is turned off and or dsp they are.But probly from me messing with computer so much.I'm just glad I got it up and running again.Thanks Mike
