DSDPlus Error on startup
icarus1963
Brantford, Ontario
I received an error message, seen below, that has never come up in the past.
I took a look at the frequency file and all seems to be right.
Any help would be great.
Thanks,
Andy
dave3825
Suffolk County NY
It's all about that out of place comma.
Comma should by right after NEXEDGE48, not right before 202 in line 33.
dave3825
Suffolk County NY
Do you have more than one frequencies file on your PC? Error specifies line 33 and that comma was in the wrong spot.
icarus1963
Brantford, Ontario
No. Just the single instance of the frequencies file. Yes after you pointed it out i realized the error.
Even with the correction made, the error persists.
GTR8000
NY/NJ Database Guy
BEE00
Try removing the leading space you have for each line. Not sure if the software is being that picky now, but it may be getting hung up on that.
cg
Connecticut
You could try adding a semicolon to the front of the line and restarting. If it does not show the error, retype the line without the semicolon and restart. There could be some odd character in the line but not the other NEXEDGE lines.
icarus1963
Brantford, Ontario
I ended up deleting the frequencies file, and starting anew. This has corrected the startup error.
Thanks all for your suggestions and advise.
Andy
