KPG-D1 Error
R_Rabbit10
I was updating programming on a bunch of radio's yesterday using KPG-D1 and wanted to continue this morning, however I am now getting an error message on reading my radio's, or even opening a saved file. Anyone have any insights as to what the issue might be? I hope it is not my system key. It was updated by the system administrator less than a year ago...
The data cannot be read since an invalid Home System ID or System Code and Network Category is configured for the data. To read this data, restart the FPU after configuring the System Key File or Access Key required for this file.
kd4efm
EL98 Florida
Item 1, did you program these with a system key? If so, did you check to make sure the KEY folder is pointed to the right folder in setup?
Item 2, the D1N you are using, a single instance or do you have multiple D1 Licenses in the LMC.
That is the generic error message involving a SKF that is no longer seen by D1 for said codeplug and or radio WITH A SYSKEY, that does not match. However, if any radio has a different SYSTEM KEY, you will also get the same error when you read the radio.
The SKF is LICENSE SPECIFIC. If you used a D1N with 1 activation, and then opened a another D1N with a different activation (like WIDE BAND)
then the SKF would not match the other licensed D1, again, the error would result.
R_Rabbit10
Thanks for the reply.
I don't know what happened, but for some reason the check mark for "Use Advanced System Key' under Set-up - Advanced System Key was unchecked. I checked it again and now everything seems to work. Glad it wasn't my system key, cause getting that updated takes about two weeks...
kd4efm
EL98 Florida
Thank you for reporting back.
Keep asking questions when you have them.
AM909
Radio/computer geek
SoCal
I have a crappy HP laptop, the USB ports on which sometimes do not work right after the laptop sleeps. They sort-of work, but just not well enough to read a radio completely or an ASK dongle. Shut down to power off, boot, and it works fine again. I'm guessing something like this happened, and D1 could not read the dongle, so it set itself back to non-ASK mode.
