Error removing a site in PPS V0.4.0.41
wwhitby
Autauga County, Alabama
All,
I have a site that I need to remove from my codeplug in PPS V0.4.0.41. I go to my profile, then E2 (P25 Trunking System Settings) and then to System Detail. Under System Detail, I go to Sites, find the site and delete it. It deletes fine. Then, I click ok to close the Sites window, then click OK to close the detail window, and I get the error below.
It happens every time I repeat those steps. I also tried deleting the frequencies for that site first, and I get the same error. If I go back into the System Detail, the site reappears.
I've tried it on two Windows 10 computers, and it happens on both computers. A friend with a G5 is also trying to remove a site in his codeplug, and he gets the same error.
Does anyone know a workaround to this? I did find a workaround, but it would have required me to rebuild a zone, and I don't want to go to that kind of effort.
I did send an error report to Unication using the window above.
K9KLC
Southwest, IL
@jtwalker has the only way I've ever found to do it. If you search some (which isn't necessary) I had a thread about it a while back. What he said above and was also recommended by a few others via exporting to CSV make changes and re-importing was what finally worked for me unless I just redid the whole system I was working on.
