'Error two hundred two.'
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Okay hive mind.
Here in Alberta we have a linked repeater system, that several clubs link their independant repeaters into.
Quite often, during nets that link those systems, we will hear a synthesized voice give the error code 'two hundred two' after DTMF codes are sent over the air.
Does anyone know of a specific controller brand and model that will throw out this error code?
RFI-EMI-GUY
HTTP Error codes?
HTTP errors like (HTTP 200, 201, 202, 203, 400,401,403,404,500,502 etc.)
HTTP 200 - Ok
HTTP 201 - Created
HTTP 202 - Accepted
HTTP 203 - Non-Authoritative Information
HTTP 300 - Multiple choice
HTTP 301 - Moved to permanently
HTTP 302 - Found
HTTP 400 (Bad Request)
K9KLC
Southwest, IL
I agree with Bud, sounds like a bad DTMF string being crunched or it not accepting due to poor signal or interference a DTMF string to execute a command. I've hear that come out of our Arcom controller when I messed up trying to program the time twice a year for time changes. I honestly don't have the manual in front of me and I'm not sure it showed all the errors anyway.
kayn1n32008
Sector 001
So the problem isn't that the codes are wrong. The codes are doing what they are supposed to do. The problem is that there is a device that is not ignoring codes it isn't programmed to respond to.
nd5y
Wichita Falls, TX
There was a repeater around here that kept repeating error two hundred something over and over for about a day before they shut it off or fixed it. Then it happened again about a week later.
K9KLC
Southwest, IL
This happens often on a linked system. Some controllers rather than actually mute the tones generate their own monotones then the other system Interprets that as a mistake. We fought this some in the 90s. The system in MO had a different controller and my machine would hear the tones and think it was a mistake and visa versa.
We honestly never did find a way to 100% eliminate it prior to it all coming down in early 2000.
If there's an answer I'm not aware if it. If you use PL on COR it helps keep it down some but some will still show up if you key up after the command is entered a second or two.
kayn1n32008
Sector 001
The issue isn't tone regeneration. the problem is a single controller throwing an error code because the tones being sent are not "correct" for that specific controller. The controller is not ignoring codes not intended for it. I am trying to figure out what controller brand and model will respond with the error in my OP.
kayn1n32008
Sector 001
Good luck, I've had 3 that thru a "error 202 code". RLC 2 and 3, and the club has an Arcom that will do it even today if I crunch something wrong.
THIS is EXACTLY what I was looking for. RLC 2, 3 and Arcom. That GREATLY narrows down the potential sites this error code is coming from.
Our system is a 8 port Pi based controller using SVX for our main site, and our remote sites are SCom controllers. The 'big' system we all link into uses SCom controllers.
K9KLC
Southwest, IL
Obviously there could be others but those are the 3 that I have heard that particular error come out of. Good luck tracking it down.
AK9R
Staff member
Super Moderator
Central Indiana
I've been using an Arcom controller for 10+ years. Never heard it generate "error two hundred two". But, you can probably email Ken Arck at Arcom to get a definitive answer.
I've never used an RLC controller.
K9KLC
Southwest, IL
I'll have to see which one the club has for sure, I get that error if I try and set the time wrong and miscrunch a number or something. I'll double check it. I know it makes me mad when I hear it.
Do you do a lot of over the air programming on yours?
Just curious.
AK9R
Staff member
Super Moderator
Central Indiana
No. I haven't touched the programming of mine in about 2 years. And, I did that by uploading a file at the site. I just don't like making controller changes over the air and the site is readily accessible during the day.
K9KLC
Southwest, IL
Ok, ours doesn't have that option always and usually I'm usually only doing the time change here and that's when occasionally my fat fingers make a mistake and I hear that. The only other time is once in a great while it locks itself up (on going problem that seems to have no rhyme or reason to it) maybe 3-4 times a year. Other than that we physically go to the site and use the file upload at the site. It's not worth the trip to make the time changes, and honestly it's been probably 4-5 months since I had to shut it down for a bit, again, not worth 90 minutes of driving for that little amount of stuff.
Thanks for the info.
AK9R
Staff member
Super Moderator
Central Indiana
There's a permanent fix for that problem...don't configure the controller to announce the time.
Unless, of course, you have some function that needs to be performed at a certain time.
K9KLC
Southwest, IL
it's ok. I don't mind taking 90 seconds or so twice a year to change it.
