Error when updating P7100 - Failure in Writing Radio Code
AlexCA
Canada and US (DE)
Hello everyone,
I encountered an error when trying to update the P7100 to a newer DSP code version. The radio is currently J2R18H09/F6R06M05, and I’m trying to update it to J2R18H09/F9R06N05. However, when I select the new files and click "Program," windows about Serial I/O quickly flash, and within 2 seconds, an error window appears: "Failure in Writing Radio Code."
Interestingly, the Radio Code version does not change, and it is the same in the radio as it should be after the upgrade.
I’ve tried using the J2R18H09 file with both BIN and BIZ extensions from different sources, but this hasn’t changed anything. For reference, here are the MD5 checksums of the files:
Code:
8d3e68b6a4141670877e9f093049e19d *J2R18H09.biz
8c2759c7047bdc3b97d6a991f48e2093 *J2R18H09.bin
c71b8e0fb7ff218fa0fea7d1ed4f2b3f *F9R06N05.dsp
Moreover, I cannot bypass writing the J2R18H09 file. The software insists on specifying the path for it as well. It is not possible to upload only the F9R06N05.dsp file, as the program checks this.
I am using RPM 14C05, but I can use any version of RPM or RPM2 since I have a purchased copy. So there are no problems there.
This radio is an 800 Dir FM with 2 MB of Flash. It originally came from the factory as J2R11B01/F5R06H01.
Normal programming works fine without errors. The cable is factory-made, and the COM port is hardware-based (soldered onto the PC board). Entering programming mode is done by holding the PTT while turning on the radio (for about 7 seconds). At this time, nothing is displayed on the screen, or only the channel mode symbol "A" is visible at the bottom center of the screen.
Does anyone have any ideas? This error has never been discussed on forums, and Google knows nothing about it either.
towersites
Denver, CO
JR11B01 Does not play well with 14C05. You need to find older version of RPM to upgrade radio to J2R18H09. I had that problem switching radios from EDACS to P25. JR11B01 is old code. After reading more into what you are writing that you have J2R18H09 Loaded I would try loading F7 code then go back to F9. Some early versions of radios did not like F9. When we got the code from Harris, they said to use it in our M7100 mobiles only.
AlexCA
Canada and US (DE)
Unfortunately, the RPM downgrade didn't help. I tried versions 15, 11, 10, and 6, and the error is the same.
@towersites
I never mentioned the JR11B01 code. I had the J2R11B01 code from the factory, but as mentioned above, the radio has long been J2R18H09/F6R06M05.
The issue is that no RPM version can currently flash this radio with another DSP code, because the radio code is flashed first (even if its version doesn't change! That's how the RPM program works), and then the DSP code is flashed.
So the program fails when flashing the radio code. I tried downgrading the radio code to F7R03A01 and F7R06G01, but to no avail, the same error as in the original post – "Failure in Writing Radio Code."
Does anyone have any other ideas?
snoopyII
On the other side of the tracks
Looks like you've ruled out cable failure, and (in general connectivity PC to cable) by being able to program a personality into the radio. The fact that you have tried different versions of both RPM and DSP/Radio Code, with the same result make me lean towards possibly hardware is starting to fail. Some of the 7100's are pushing damn near 20 years old.
-What OS are you using? Can you use an older machine like a Win7? Have you tried a different PC?
-Maybe slow down the baud rate of the serial port. FWIW, I understand you are using R14, earlier versions of RPM very susceptible to failing DSP/Radio Code updates if the PC was doing other things in the background. I'd disconnect the PC from the outside world, and make sure there is nothing else running in the background and slow the serial port to 9600.
AlexCA
Canada and US (DE)
The problem is called "my own fault."
It turns out that the P7100 can be put into partial programming mode by starting it up while holding PTT or PTT + 1 key. At that point, the display shows nothing, or just fragments of the operating mode (A/D), sometimes with defects. The radio is fully accessible to RadioMaint, for reading and writing Personality.
But! To load binary files, such as BIN, BIZ, or DSP, the radio needs to be turned on while holding three keys – PTT and the side buttons up and down. I didn’t know this, or I forgot. Most likely, I didn’t know.
With the correct entry into programming mode, binary files are written on the first attempt, and in any RPM version.
It all turned out to be so simple!
Forts
Mentor
Ontario, Canada
That's strange that it wouldn't work when the radio goes into programming mode on it's own, but none the less... glad you got it to work!
AlexCA
Canada and US (DE)
Sorry, but where did I say that the radio goes into programming mode on its own? I never claimed that, and I was writing about something entirely different. You seem to be very inattentive, as I've noticed, and you're leaving comments everywhere without understanding the essence of the issues, just to inflate your post count (I've seen this in many of your posts in this section).
Forts
Mentor
Ontario, Canada
Yes you are so right. 23 years on this site and just shy of 7000 posts later I'm still working on getting that post count up. I'm willing to bet a few others here don't share your opinion of me, but hey to each their own. Good luck with your future endeavors.
