Error with Wide Band Entitlement Key
stevez97
Myrtle Beach, South Carolina
First shot at programming Mototrbo, so please be kind. <grin>
I downloaded from MOL CPS 16 Build 828 and am attempting to input the Entitlement Key for Wide Band that I obtained from /\/\. When inputting this key into the "Register Device Features" I get an error # 3764 - "The EID entered cannot be used to register or view device features."
Any ideas or suggestions?
Thanks in advance for any advice.
n3obl
O AES-1024
PA
Thats a common mistake I see with Trbo CPS when trying to activate the wideband key. Everyone wants to use device features instead of application.
Remember the wideband is not tied to the device but the software install "Application" on the particular computer.
com501
The wideband EID should work with Trbo2 also. If not, tech support can issue you a new ID with whatever amount of devices you have left on your entitlement.
