Etrunk 3.83 Documentation
kd5dga
Killeen,Texas
I dug out my 2 level dataslicer and decided to put it to work. I downloaded ETRUNK 3.8.3 and installed the program. I have the program up and running. Is there any information that I can read on ETRUNK?
Now I can run two decoder program at once with two different systems.
Thanks in advance.
kd5dga
Killeen,Texas
No documentation with the download. The zip file came with two .exe files on for 9600 and one for 4800 systems.
I am using this for a second scanner that is not occupying my soundcard.
You may find the PDF bundled with DOS Trunker - I think it describes both Motorola and EDACS versions.
FYI: the new generation of UniTrunker allows monitoring two sites at once by using the left and right channels of the same sound input. Moreover - if the two sites belong to the same system - you don't need to copy data back and forth between working folders.
kd5dga
Killeen,Texas
cool on the next version of unitrunker. The only problem I have is I am running VISTA now.I am running the older version of UNITRUNKER until a vista compatability is available.
Surprisingly, ETRUNKER is running great under VISTA.
