Evergy (KCP&L - Westar Energy)
kctracker1
KCMO
What I've learned so far about the DMR TIII System
Built by Tait Communications TN9300 network TP9300 Portables TM 9300 Mobiles 23 sites associated with the system
Crews work out of the various service centers
Talk Groups
6200 Johnson County Service Center 108th and Renner Evergy Kansas Metro
6300 F & M Service Center Front and Chouteau Evergy Missouri Metro
6400 Southland Service Center 199th and Newton Evergy Kansas Metro
6500 Northland Service Center Platte Purchase and Barry Road Evergy Missouri Metro
6600 ?
6700 Dodson Service Center 87th and Prospect Evergy Missouri Metro
Sites 1.6
152.0375
152.5325
152.6225
152.5175
152.6600
152.8175
2.6
152.0825
3.8
153.4550
153.4100
152.5025
153.9950
155.9850
152.0525
152.5100
152.7275
A work in progress Have them in my TRX-1 Fairly Active
hkrharry
Member - RR DB AdminMo/Ks
In the middle of the USA
KC Tracker what are the numbers 1.6, 2.6, 3.8?
Are these site numbers or what?
Is there any Time slot or Color Code info?
Can you share any TRX screenshot of your programing info, I am not real familiar with my TRX and DMR just yet.
Perhaps you could share your programming file, If so PM me for an email address.
kctracker1
KCMO
Didnt have to worry about time slot or color codes use the ez scan software that came with the trx-1 set it up in trunk system as evergy and enter the data from the screen shots
kctracker1
KCMO
sorry forgot the 3 site
BigC801
Kansas City
I have it different for site 24 (3.8) Ill try some of your stuff and see what works better.
; Site 24
TIII, 01, 3.8, 09, 152.0550, 0.0, 1
TIII, 01, 3.8, 10, 152.0550, 0.0, 2
TIII, 01, 3.8, 21, 152.1875, 0.0, 3
TIII, 01, 3.8, 22, 152.1875, 0.0, 4
TIII, 01, 3.8, 31, 152.5325, 0.0, 5
TIII, 01, 3.8, 32, 152.5325, 0.0, 6
TIII, 01, 3.8, 43, 152.6250, 0.0, 7
TIII, 01, 3.8, 44, 152.6250, 0.0, 8
TIII, 01, 3.8, 61, 152.8175, 0.0, 9
TIII, 01, 3.8, 62, 152.8175, 0.0, 10
kctracker1
KCMO
I'm not sure if I am really DMR or just scanning the channels. Tracked the system using DSD+ and two RTL Dongles
; Site 24
Let me know I may have them on the wrong site...........
KC_zero_DSU
Kansas
I hadn't found this thread yet, glad I did though. I've been hoping to figure these KCPL sites out more completely. Any updates anybody?
This is what I have on one of the sites I pick up down where I am at about 60 miles south of KC. The KCPL/Evergy power plant is just 4 miles to the east of me. But in the plant they use 900mhz band freqs and also some up in the gigahertz bands.
DsdPlus.Sites
TIII, 1, 2.8, "KCPL-2.8"
DsdPlus.Frequencies
TIII, 1, 2.8, 45, 152.06875, 0.0, 0 ; DCC = 0 CC
TIII, 1, 2.8, 46, 152.06875, 0.0, 0 ; DCC = 0
TIII, 1, 2.8, 11, 152.02500, 0.0, 0 ; DCC = 0
TIII, 1, 2.8, 12, 152.02500, 0.0, 0 ; DCC = 0
TIII, 1, 2.8, 59, 152.75750, 0.0, 0 ; DCC = 0
TIII, 1, 2.8, 60, 152.75750, 0.0, 0 ; DCC = 0
The rest of the freqs I don't have the channel numbers for but the freqs are
152.21750
152.56250
152.65500
From what I understand you only need one channel # for each freq and DsdPlus will do it's thing.
The other sites I pick up and have in the .sites file are below, but I have nothing else on them yet. Yesterday would of been a prime day to listen and figure stuff out with the storm that rolled thru and lines down and power outages. But I was too busy cleaning up the aftermath and trying to fix/replace my antennas and other stuff that got tore up. I was rocking two generators. A 3500w inverter generator for all the radio gear and electronics stuff and a 7500w for the rest of the house.
TIII, 1, 1.2, "KCPL-1.2" (it's on 152.20625 ??? I think, that's what I pick it up on anyways)
TIII, 1, 3.3, "KCPL-3.3" (it's on 152.1750)
bctrainers
Olathe, KS
Been having DSD+ monitor 152.06875. Heard a smidge of audio, but it's been fairly quiet, unlike KC MARRS system. :)
SDR# seems to have a severe tuning bug right now, so the MHZ values aren't updating like they should - not sure what's going on there.
Also, here in JoCo, I am seeing another DMR system just a few above 152.06875, with a weaker received signal. It's very quiet after 15 minutes of listening to it.
N0JRD
Topeka,Ks
Do they have a site in Topeka? I haven't been able to find them anywhere in Topeka on vhf or uhf?
N0JRD
Topeka,Ks
I haven't heard anything on the 900 mhz in months. I can still here the control channel but nothing on the system.
kctracker1
KCMO
KCP&l and Westar Energy have both migrated to the DMR system wide under Evergy. I dont have any info on other metro locations served by Evergy. I did alot of digging thru the FCC site to find most of the freqs so far, but the fcc database is a disaster......
N0JRD
Topeka,Ks
Do you have a list of the freqs? All I can find are the old 900 and some uhf ones that are only mobile licenses.
kctracker1
KCMO
I dont have any other than listed above at this time, let me do some digging and see what i can come up with for Topeka and Lawrence
kctracker1
KCMO
The following freqs are listed for Evergy Topeka in the new system cant tell you the order but plug them in and listen:
152.0150-152.0450
152.0450-152.0750
152.5250-152.5550
152.5550-152.5850
152.6150-152.6450
152.7050-152.7350
152.7350-152.7650
152.7950-152.8250
If you can set up dsd+ and monitor to get site # and channels.
Best I can do right now let me know what you find!
wbloss
Human
Joplin MO
Did anyone capture the color codes?
I'm getting a DMR marker on 152.3075 that could be the Miami, MO site of Evergy with cc of 12
thanks
w
BigC801
Kansas City
thanks
w
So far all of the KCPL sites have always been CC 0, but it was just licensed to Evergy so they could of changed things up. Is it DMRT3?
KCoax
Has anyone figured out some of what seems to be zone sub-talkgroups e.g. 6201 - 6207? It sounds as if it is a large work scale ticket calls or an event channel for that zone. All the zones seem to have them.
