EVX-5400
Bill1957
New Jersey
Hi,
My evx5400 no longer does wide band on the amateur 70cm band. Does digital fine.I was using the export software from the Vertex site.My radio has cpu/dsp 1.22/1.12 and software is CE142 ver 1.14. Did updating firmware and using new software prevent me from using 25khz? If so,is it possible to go back to an older firmware version and older software? Any ideas?
Thanks,
Bill
Bill1957
New Jersey
EVX 5400 Firmware
Installed older firmware ver V01-19-01-10 and wideband analog was restored. Any 5400 users beware that
you will lose wideband analog if you upgrade to a higher firmware. Always save the older versions of firmware and software.!!!!
Bill
wx5uif
Broken Arrow, OK
Looking on Vertex online, there are separate versions of CE142. One for wideband, one restricted to narrow. Did you try the wideband one?
Bill1957
New Jersey
EVX5400
Hi,
Yes,was using the wideband export version and still no wideband until I reverted to the older firmware.
Bill
Gashliquor
Wrong!!!
Hi,
Thanks,
Bill
Hello Bill, First off you might of seen posts of mine before. I do exclusive testing on Evx-5400 VHF Radios only! and report errors found to VS.
This is the problem, You had firmware 122.112 and International programming software and were still narrow band with this firmware this is why.
Install the 122.112 firmware, Then run (Wide_Band_Recovery_Tool_1_02) which can be had at VS if you have a account. It is NOT found where the programming software is!!.
Now as per this message use the newest version of the INTERNATIONAL programming software and you'll be Narrow/Wide band where ever you want.
WARNING: DO NOT INSTALL: 124.113 firmware, I made them pull it from there web site as it disables ANALOG receive!!, Vertex Standard even with critical problems lags in fixes that Motorola should be ashamed of themselves. Even if you don't use ANALOG you should NOT use this firmware. It should no longer be able to be downloaded. If you or anyone else DID download and install it before it was pulled re-flash your radio with 122.112 firmware. My own warning about Vertex Standard is all firmware comes from Japan and is not beta tested in Japan or the USA. You are the guinea pig.
It also does NOT matter if your 5400 is VHF/UHF
Gashliquor
By the way you aren't going to get 25Khz on wide more like 5Khz in W5 mode, 25Khz isn't gonna happen.
W5" (Wide 5k)
Max. Deviation = ±5 kHz
Option
Functionality
Limitation
"W5" (Wide 5k)
In USA, if frequency is set to 150-174MHz or 421-470MHz, it is limited to "N" by FCC rule.
"W4" (Wide 4k)
Max. Deviation = ±4 kHz
"N" (Narrow)
Max. Deviation = ±2.5 kHz
