jeffdafoe
I found this discussed before with regards to streaming, but if you're using the SDS100 at home with an amplified speaker, you can get fantastic audio levelling if you add a compressor. I have a small home recording studio and I had an FMR Really Nice Compressor (RNC) sitting unused on a shelf. The RNC settings are theshhold at minimum, ratio 4:1, everything else at noon and "super nice" on. The SDS100 is at vol 10. The audio is smooth as butter no matter how quiet or loud the talker is.
I do run with the scanner plugged into the USB port on my PC and this did cause noise under the setup above. I used a isolation transformer (ART Clean Box II) after the compressor and it went away completely.
