I am scanning a lot of local DMR frequencies but when I look at the logs (and listen to the recordings) it is very confusing without seeing the frequencies associated with the Channel/Talkgroup/Radio. I read that if you use the -E switch then you get Extended Logging which then adds this information in the logs. Unfortunately, this switch does not actually seem to be supported (any more?) and I get an error to this effect (invalid command line parameter: '-E') so I am just wondering if there is another way to achieve this?
I am using the latest version of Fastlane DSDplus with a TCP link.
Any suggestions appreciated!
