Anyone ever use an external battery pack for longer scanning? Something like the link below.
When I have mine on the table for home scanning with roof antenna I use a USB 5v power supply. My USB volt/current meter doesn't have enough resolution at that low current that the 436 draw but it flips between 70mA and 100mA and when receiving audio it stays on the 100mA value. Those mini 2AH powerbanks for $5 or $10 will then last for 20 hours on one charge, so good for one whole field day on just the external bank without even using the internal batteries. It's a huge difference to a SDS100. I top up my internal batteries with two months intervals if I only use the scanner at home.Anyone ever use an external battery pack for longer scanning?
See if this is what you want.Got my battery pack charged up so will run it until its almost dead to see how long I get on one charge. Anyone know if someone makes a smaller cable with a right angle so the cable runs down the side of the scanner? To easy to damage the radio from the cord sticking out the side when moving it around.
The one I posted above is 9 inches. If I can find a case that fits both radio and battery, the smaller cable will be easier to manage in a case.
