Programming the XG-75M
Prospect62
20 year member
Oneida County, NY
Can anyone recommend a reliable USB to Serial cable for programming an XG-75M? I understand that a serial 9-pin to serial 9-pin cable is preferred but neither of the two computers I use for programming has a 9-pin serial port. I was looking at this one because from what I gather the FTDI chipset is a must if going this route:
Is there a particular cable that is reliable and stable?
Prospect62
20 year member
Oneida County, NY
For posterity...
I was able to find a good answer in that the SeaLevel 2105R seems almost universally recommended, with quite a few people adding that any DB9 to USB cable will work well provided it has the FTDI chipset. Further still, some say that any off-the-shelf USB to DB9 cable you get at Best Buy will work also.
I'm going to try to keep costs down by attempting the reputable cable with FTDI chipset posted above. I'll report back with results.
merlin
DN32su
With a PC lacking a DB9 serial port, you are much stuck using a USB to RS232 adapter cable. As recommended, a cable with genuine FTDI chipset there should be no problems. ($10 and up)
The DB9 F to DB9 M cable is nothing more than an extention cable and anything generic will work. ($10)
This setup will actually work with any radio that uses a DB9 programming port provided the software supports USB.
Radio specific programming cables with DB9 F can be used and works. (software dependant)
XG-75 are quite easy to program, I use RPM C-14 for everything Harris. the above configuration has always worked.
