BCD436HP/BCD536HP: external power question
dave3825
Suffolk County NY
When your powering the scanner via the usb cord, is it truly using just external power?
The reason I ask is because I am charging the batteries in an external charger and running the scanner off usb power from the computer. I tried to do a Discovery mode session. I get a message saying "Can not start discovery when batteries are low or not installed"
Why does it need Batts installed if it has an external power source?
UPMan
In Memoriam
Arlington, TX
Because the discovery feature uses recording, which is disabled when batteries are removed to help avoid SD card corruption.
dave3825
Suffolk County NY
OK, so if one was to use 3 dummy batteries,while plugged into USB power, would that tell the scanner the battery circuit is complete, and enable the record feature? And would that hurt anything?
UPMan
In Memoriam
Arlington, TX
I don't believe dummy batteries would work (might even be detrimental to have a dead short across the battery terminals, which is what dummy's would do). Why not use real batteries?
dave3825
Suffolk County NY
Just asking. I have a few dummy batts just sitting in the drawer. I usually keep the reachable batts in the charger until I take the scanner outside, I really need to get a few more sets of batts..
marksmith
Anne Arundel County, MD
Pretty sure dummies would not work. Recording is disabled when the radio senses batteries are low. Might also do it when they are not there.. but when batteries get low the recording function stops.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
Voyager
Dummy cells likely contain no voltage, hence the scanner would see them as 'dead'.
