Retevis External speaker for RT3S
wagros
Sao Paulo, SP, Brasil - GG66qk
Hello, friends.
I bought an external speaker to connect my RT3S in the car, but the audio quality is quite poor.
I plan to replace the speaker in the box, but since I have no knowledge of electronics, I have a question. The speaker in the box has an impedance of 8 ohms. Is this compatible with the audio output of the 2.5mm pin on the radio? Could I, or should I, buy a speaker with a different impedance?
Any help would be greatly appreciated!
Issue is likely that the radio does not have enough power to drive that speaker. Common issue with hand held radios.
You'd want to use an amplified external speaker, or, upgrade to a mobile radio. Replacing the speaker in the housing isn't going to fix the issue.
wagros
Yes, it does work, and even at a good volume.
The problem is the quality of the audio it produces.
I thought about using a higher-quality speaker, but then I started wondering about impedance.
I also considered buying a small 5V amplifier to place inside the box.
I didn't consider a mobile radio because I use the RT3S to entertain myself by listening to public service transmissions while driving.
OK, might be that the little amp in that radio is just working too hard. Not sure a different speaker will fix that, but it's something you could try. Usually the internal amplifiers are capable of a watt or so at the most. Usually much less.
wagros
I think I'll go with the idea of adding a small speaker box with a mini amplifier powered by the car's USB port.
Thank you for the help, mmckenna!
slowmover
Fort Worth
wagros
Wow, cool speakers!
But... I'm Brazilian, and besides the shipping costs, our corrupt and wasteful government taxes imports over $50 at 92%.
Still, I appreciate the suggestion!
