arnie920
I have a TRX1 scanner. What would be a good external speaker for this unit. I guess I want one that does not require power. I have no access to power for the speaker.
Have you tried using a Bluetooth speaker w/ aux input? I have one that I used on my phone and works great on my Uniden and GRE scanners. The only thing is that on some scanners, you might have to purchase a stereo to mono adapter to hear the audio. Internal battery on my speaker lasts about 4-5 hours before having to recharge.I have a TRX1 scanner. What would be a good external speaker for this unit. I guess I want one that does not require power. I have no access to power for the speaker.
Real good idea I had not thought of that.Have you tried using a Bluetooth speaker w/ aux input? I have one that I used on my phone and works great on my Uniden and GRE scanners. The only thing is that on some scanners, you might have to purchase a stereo to mono adapter to hear the audio. Internal battery on my speaker lasts about 4-5 hours before having to recharge.
you might have to buy a speaker with some sort of amplification.
Most hand held scanners are designed to be used with headphones, not external speakers. The power requirements of both are very different.
....ebay search bar type in SH2P4....
It comes up as three different versions.
One is a square cube and another one has more rounded corners and a third have a volume control on the front.
/Ubbe
Get one with good base. It will sound awesome.
Normally a speaker with good bass response is undesirable for voice, if clear intelligible speech is your goal. Typically one with a frequency response of 500Hz - 20kHz. A speaker with a low frequency response down around 20 - 40Hz might sound muddy.
Well this is what I ended up ordering.
https://www.amazon.com/Standard-Por...328&sr=1-61&keywords=battery+powered+speakers
For the price if it sounds bad,then I'll get something else. You don't know unless you try it??
Well I got the speaker, it was delayed because of the holiday.Looks like a nice speaker. Let us know how you like it.
Well, the old saying: "You get What You Pay For"
Enough said.
Enough said.
