EZ Scan Export Question
mikeshepard
El Cajon, CA
On the latest version of EZScan. When I go to a trunked system TG detail tab and right click, I have the option to export all or selected TG objects.
No matter what I try, the program exports a random subset of objects or none at all.
I tried the same export option for Radio Ids and EZScan exported perfectly.
Anyone else run into this issue?
Most likely the reason is the TG's were downloaded from the RR database, while the RID's were not. Do to the agreement with RR any item downloaded from the database is not supposed to be exported. This was announced when the feature was added.
mikeshepard
El Cajon, CA
mikeshepard
El Cajon, CA
Ok thanks. I wondered if that was the case. I was trying to export the TG IDs as we will be switching over to a new system here in San Diego County shortly and the new TGs s will be the existing objects divided by 16. I was trying to get ahead of the game by downloading to Excel and then doing a mass-change via formula . I guess I'll need to wait until the DB is updated in RR or make the changes manually.
