PSR-800: EZscan updates
AuntEnvy
Central New York
Hey folk ~ Something I've been meaning to ask with regard to updating the library/stored data...
In the updating your stored data section there is a column that says "skipped" with whatever numbers next to each line. What is it skipping exactly? Is it the alpha tags/channel names that I've created or something else?
Thanks.
JD21960
ILL-annoyed
EZSCAN-Updates- skipped
The "skipped" column in the trunked and conventional tabs where you store frequencies/talk-groups shows things you skipped while scanning by hitting the "skip" button on the front of the scanner. If you're scanning, get a birdie or some frequency that's loud and obnoxious for some reason, you simply hit the "skip" button and it is stored in a temporary list until you decided to restore them. They show up on the EZScan software as being skipped during scanning. YOU can restore them on the scanner itself by pushing menu/settings/scroll UP to "Restore Skipped" The photo below is my EZScan from my WS1080 showing a few skipped frequencies.
