F1721D Scanning Issue
HVFD2012
Pampa, Texas
I'm sure that this has been asked several times already, but I couldn't find a post about it. My dept is upgrading to the P25 system now. I have a F1721D that I am going to be using in my POV. I'm in the process of programming it now. My question is, when I take to mic off the hanger it still continues to scan and I miss out on the transmission. I've tried to change the options on the scan feature but I can't seem to find the right combination. Is there a way to set it up so that if i take the mic off the hanger it'll stop scanning on the transmitting channel or a way to program one of the buttons so that it can be pressed and hold the transmitting channel? I ran into this issue with my 5021 also, but can't remember what I did to stop it when the mic was off the hanger.
Thanks in advance
HVFD2012
Pampa, Texas
Thank you for the reply, I've tied to enable and disable the hanger action and neither one stops the scanning process. I think I read somewhere that there might be a time limit or something like that. Is that correct or am I mistaken? If I increase the time limit, would that help?
12dbsinad
Make sure hook on scan is set to on. Make sure when you start the scan you're only doing a quick press. A long press of the scan button will enable the scan list program mode and look like it's scanning. Make sure your Timer A and Timer B settings are set to zero.
The only other thing that could be going on is someone possibly bridged the mic internally or inside the front cap to allow scanning off hook, or un-grounded. Those older radios didn't allow off hook scan via programming so you'd need to mod it. If modded mic try unplugging the RG45 mic connector while it's scanning and see if it cancels.
HVFD2012
Pampa, Texas
Thank you sir. I'll change the settings on the hook scan and check the timer. I appreciate the reply and will let you know what happens.
