F221
fot316
Can anyone help me with programming this radio,,, I have a 1122 cable and I think the software is fc1000 and my computer is a HP running 8.1. I can not get the com to recogniz. Any help would be appreciated
CSF-100 is the programming software you want.
OPC-1122 is the cable.
Been a while since I programmed one of those. I used to have an F-121 and an F-221. I used the older RS-232 cables and never had an issue.
Make sure you have the right USB driver, have the right comm port selected in the programming software.
fot316
My computer won’t recognize the usb as a comport
DeoVindice
P25 Underground
5150 Level
Go into Device Manager and see if the USB cable shows up. If necessary, you can change which COM port it uses through the device settings - some programming software will only recognize COM ports 1-4 or similar.
