F33g Question
lucas2121
Does anyone elses radio have the audio just quit for about a second then come back in?
Example: Engine 5-3 to county
Dispatch:Engine 5-3 go
Engine 5-______oute
I can hear it on my pager but the radio will just cut in and out like that. Does this happen to anyone else?
I'm rather OCD about things working like their supposed to, lately I've had bad luck with radios.
bezking
On the Road
Never had that happen to me. Were you in scan mode when that happened? Or try disabling the PL tone and see if that does anything.
lucas2121
It happen when it was on scan and off...now it's not doing it. Could it be over loading or something?
I don't know to much about stuf like that
dwh367
Amateur Radio Operator
Owensboro, KY (Daviess County)
One thing to try is to put your radio into the "monitor" mode (bypasses any PL/DPL tones). If this fixes the problem, then the radio is just slow to decode the programmed PL/DPL tones.
If that doesn't work, it could be the sleep timer settings that are programmed into the radio. Someone with the correct software would have to take a look at that for you.
lucas2121
It does it in monitor mode, I just looked though the software and the "battery Saver" is on so I think I'll try turning it off if it keeps it up.
