F3621DT Read/Write Issue
RadioDitch
Field Operations Member
Not Where You Think
Evening all,
I'm attempting to read/write an IC-F3261DT using an OEM Icom OPC-1862 cable with Version 3.4.63.22 drivers through CS-F3260 ME 4.6.4 on a Windows 10 machine through COM 1. It does attempt to read the radio, as shown by both the computer and radio display. Going to Clone Information will display the radio's version and information. Unfortunately for read/write I keep getting this error when I attempt to.
The radio is equipped as follows:
REV 5.5
SUM66FE
BLD CEEC
UT-126H
DREV 3.2
DSumF961
Can anyone provide some guidance? Thanks!
RadioDitch
Not Where You Think
Just gave CS-F3260 RR a shot also, and no joy. Possible I need a newer version of CS?
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
I've got a couple of new F3261DT (hopefully -RR) sitting here with factory (I assume) programming. What's the approved method of acquiring legitimate programming software? Or at least pointers to a cheat sheet to know the steps from here? TNX.
Bote
know-it-all
Eh, if it's something that I absolutely, positively MUST read off a CD then I would splurge, but it turns out the guy handed me a USB thumb drive disguised as a thick credit card. So I got the proper software right from the source. (I also no longer have a 3.5-inch floppy drive nor a 5.25-inch floppy drive.)
I'm not overly impressed by the lack of receive sensitivity, but I have not used the accompanying "adjust" software which might allow me to give it a supertweak.
