F70 Scanning ?
Seymourmtn
Seymour, Tn
Greetings
I have inherited a F70DT and trying to work through the programming software
1. I can’t get the Help section of the software to open. Is this a windows 10 issue?
2. Is there a way for the San fu cation the show what channels are being scanned. Currently, y screen on,y shows “Scanning”
thanks for any help
Doub
12dbsinad
Greetings
thanks for any help
Doub
1) Is this a legit copy of the software? If not, this could be why.
2) You can tell what is in each scan list in the software on the memory screen scan list. The other way to tell is to program a button for scan add/delete. Use a P0-P3 button. If the channel is in scan the "SCAD" will be highlighted above said button, if it's not than it won't be in scan. Simply pressing that button will toggle the channel. You'll need to go through each channel for this.
Seymourmtn
Seymour, Tn
Yes it is real And I have the CD. When I click on the Help it takes to to a Microsoft page advising that the files can’t be read. I unnderstand that this is old software but....
thanks for the scan tip
Vern
Union County, GA
Your First Issue:
Most of that software was written for older versions of Windows. Starting with Windows 7 (or maybe 8) Microsoft used different file structures for HELP files. So the newer versions of Windows won't read those old HELP files. I had similar problem with first version that I got for the CS-F3060_F5060 cloning software. When I found Ver. 5.3 the HELP screens worked under Win.10. See if there is a newer version cloning software for the radio you're using.
Your Second Issue:
I can't specify solution for your radio as I haven't used it or the software.
For the CS-F3060_5060 series, I found that there was programming page titled SCAN > SCAN LIST which had each "Scan List" on a separate row. In the next-to-last column of each List's row was a column labeled "TEXT". If I changed the contents of that cell to "OFF" then the radio's display would scroll every channel being scanned real fast. If I left that cell with a selection called "TEXT" the display would act as you described and not show any scanning action.
Hope those items apply to your problems or at least steer you in the right direction.
73 de Vern
