Is Fairfax County FD fully operational on the P-25 system?
It's going on three days now with no Fire or EMS calls for me. I'm getting all the police channels just fine, however.
I updated my library to the latest release (141; released on 6/23/12) and I'm using a PSR-800.
Today I heard two calls from radio techs who were troubleshooting some radios on 4B and 4J but that's been it...not a single dispatch call at all.
Totally believe something is or was going on but I was out of Fairfax until today. Also I have noticed that some EMS calls still show up under the Radio Tech (or is it test) heading. However I am running both old and new concurrently on my 996XT and it appears all is on the new system.
The last update to the Fairfax County P25 system in the DB was 6/21... if there haven't been any updates since you started experiencing problems, then it's not likely that the next update to the files will fix your problem... unless there's an update submitted to the DB before Saturday (which is when GRE updates their files).
I'm going to bring my scanner to work tomorrow and do some control channel monitoring on the P25 system so I can see what's going on.
do you by chance have your scanner closed to just what you put in or set to where it scans just the cc and picks up everything?
o ok thats where i got confused then i know thats the 106 has a setting where you can either scan what you program in or you can open scan thats what i was talking about open scanning and making sure you had the right tgids and what not programmed in
