Favorite list question
fdnyfish
Barnesville, PA
So is it better to have Fdny, ems, NYPD, papd each as a favorite list? , or should they all full under a favorite list called NYC?
What are advantages and disadvantages of each way
Thank you, my 436 is on order
tglendye
Blue Ridge Mountains, Shenandoah River- VA
Any way you want. You can do it separately and create another FL for each service, agency or pretty much anything. You can listen to a single FL or multiple at the same time. Or you could do one list and put everyone there. The SD card has a lot of room for programming so the programming is pretty much limited to your imagination. Enjoy!
phask
zanesville
Depends on which scanner,IMHO. I'd do a HP1/2 different than a 536.
One COULD do 1 FL in a 536 and a lot of QK.
ofd8001
Louisville, KY
As noted above, you can do it either way. Whichever is easiest for you to remember would probably be the "guiding factor".
That said, having separate Favorites Lists reduces the number of keypresses to toggle a given thing on/off.
