FBI help
d_strong
Rochester, NY
Does anyone know what if any frequency's the FBI uses in western NY Buffalo and Rochester area. Would the frequency's be the same that are used in NYC/NJ area. Thanks
Saint
Fort Erie Ontario Canada
F.B.I. Frequencies
In Fort Erie I listen to the F.B.I. in Buffalo NY on
163.8625 F.B.I.
163.9125 F.B.I.
163.9500 F.B.I.
163.9750 F.B.I./Border Patrol
167.2250 F.B.I.
167.2875 F.B.I.
167.4125 F.B.I.
167.5375 F.B.I.
167.5625 F.B.I.
167.6875 F.B.I.
Steve
Joseph11
164.5500 R - FBI D1 (Organized Crime Task Force (OCDETF)) - PL 167.9 Hz
164.5500 S - FBI D2 (Organized Crime Task Force OCDETF (D1 simplex)) - PL 167.9 Hz
166.4625 S - FBI D3 (Departments of Homeland Security and Treasury Common) - CSQ
167.5625 S - FBI D4 (FBI Common) - PL 167.9 Hz
167.5375 R - FBI D5 (Special Operations Group (FBI SWAT)) - PL 167.9 Hz
167.5375 S - FBI D6 (Special Operations Group (FBI SWAT) (simplex)) - PL 167.9 Hz
163.1000 S - FBI D7 (Federal Common) - CSQ
155.4750 S - FBI D8 (Nationwide Law Enforcement) - CSQ
EDIT: Updated D3's and D7's descriptions.
d_strong
Rochester, NY
Fbi
Would the Buffalo NY frequencys be encrypted or in the clear and would the PL tone be 167.9 Hz Thanks.
SCANdal
Silent Key
Hudson Valley, NY
Joe11,
Just two updates for you...
D3 should be updated to "Departments of Homeland Security and Treasury Common"
and
D7 should be updated to read "Federal Common"
SCANdal
wc8i
Marion, Ohio
I see there was a lot of responce to the fbi freq in ny, does anyone in ohio around the canton area no if It is even possible to receive them with a pro-96 scanner, and if so what frequencies would you put in to monitor them, thanks again guys, Bill
davidd2957
Suffolk County N.Y.
Frequencies Posted by Chris Parris from Monitoring Times
Chris Parris, who is an Editor/writer for Mointoring Times took a trip to NYC June 2006.
These are the Fed. Frequencies he logged in his Blog that he tuned into:
164.3375 D251 Repeater
166.3250 136.5 Repeater
167.1500 167.9 FBI - repeater with squelch noise, not DES
168.8250 P-25 Unknown - clear/encrypted surveillance
169.4125 P-25
170.4250 P-25
170.4500 P-25
172.4750 167.9
172.8250 P-25 FAA @ JFK
172.9000 P-25 TSA @ JFK
173.2000 Telemetry
173.6625 P-25 "Operations - Alpha 1"
406.1500 P-25
407.8125 Motorola control channel – Trunked System B12E
408.0000 151.4 Repeater
408.1000 P-25
408.1250 P-25
409.0250 110.9 Repeater
409.2750 127.3 Repeater
410.2000 127.3 USPS
410.9500 CSQ FAA Data
413.7000
413.8625 Paging
415.9500
417.2500 Analog repeater
418.2500 156.7 DEA (?)
418.3500 Motorola control channel – Trunked System 3517
418.9500 156.7 DEA - OTAR
417.2000 P-25 DHS Federal Protective Service
Enjoy...for what it's worth
David D.
davidd2957
Suffolk County N.Y.
Joseph...are the frequencies listed ones that you personally logged, or just frequencies posted by someone else on your website??
David D.
