Installation instructions:
Click on the download link above.
Choose "Open this file from its current location" and click on the "OK" button when prompted.
When the installation has completed, restart your browser (if its open) and you should find a new menu item called "ieSpell" under the "Tools" menu, as well as a new icon on your toolbar. Note that the toolbar icon will only appear if you have not customized your toolbar before. If you have customized your toolbar before, you will have to manually select the icon in the "Customize Toolbar" dialog.
Usage instructions:
If you are using Internet Explorer, you can access ieSpell in one of the following three ways:
Under the "Tools" menu, click on "ieSpell" item to start the spelling check or click on the "ieSpell Options" to configure ieSpell.
Click on the ieSpell toolbar button (if enabled) to activate the spelling check.
Right click in the browser and in the menu that appears, click on the "ieSpell" item to start the spelling check or click on the "ieSpell Options" to configure ieSpell.
If you are using a browser based on the IE engine (e.g. AOL, MSN, NetCaptor, NeoPlanet, etc), then only the last option (i.e. using the right-click menu) is available to you.
Is it in your IE Menu???????
