Ah but you don't need or particularly want a dongle. Basically this:
Uhf receiver tuned to an active signal in wide FM mode
Tap the wide FM discriminator chip (not the discriminators you see for decoders) the WIDE FM chip
Route that tapped unfiltered wide FM discriminator into the microphone port of the PC
Set the sound card to to at least 120 kHz bandwidth (up to 190 is fine) but 120 is perfect
Use SDR# or similar with the sound card set as the receiver
The signal will appear as a series of vertical thin stripes. Those are the 2600 Hz off hook tones
Voice signals will appear every 8 kHz alternating LSB USB etc...
To get real fancy edit the SDR# config file and add in 8 kHz tuning step below the 8.33 step.
Add in one of the frequency manger plugins and create voice channels at every 8 kHz
That's it.
Crystal clear audio every time.
I suppose virtual audio or VB cable would work to route wbfm audio from a dongle into another instance of SDR# but I haven't tried that yet. I will have to experiment with that.
Makes sense. The scanner is the receiver. The software is the decoder. Maybe I'll break out that old Bearcat 9000XLT sitting in a box somewhere and tap the chip on that one. I have the schematic around somewhere too. Don't want to mess with my newer radios if I don't have to. See, I told the wife I would use all of that "junk" someday...:lol:
PS , sorry moderator for getting off topic here
