FHP ID #'S
bravo14
Polk County FL
Florida Highway Patrol
I hear a few channels from the FHP. I live near Jacksonville, Fl. I hear them from far as Bervard Co. I looked on the RR site for the state trunking for these ID#'s they don't have it listed.
22768
60848
23184
I have no idea what these channels are. I heard a trooper is going to a house fire in Bervard Co. I didn't know FHP went to house fires? I do not hear Jacksonville or Putnam FHP at all. My county still uses the vhf comes in crapy.
W4KRR
Coconut Creek
What county do you live in? I thought that near Jacksonville, the state is using the new MACOM ProVoice system. Are you hearing FHP Motorola digital communications?
FHP normally wouldn't go to a house fire, so are you sure that it's FHP that is the ones responding to that fire? Maybe it's the state Fire Marshall, they also use the state trunked system.
You said your county is still on VHF, I'm confused, are you talking about the state of Florida system, or the county police? I thought FHP no longer used VHF anywhere.
bravo14
Polk County FL
I live in St Johns Co. I went to the FHP web site and they had 2 different house fires they went too. The channels were digital. I still have no idea what the ID#'s are yet. St Johns Flagler still uses vhf. Thanks again.
wsmoore
Jacksonville,Fl.
FHP still uses the vhf stuff as a backup to the MA/Comm system.I know St.Johns County is still using the vhf stuff for a lot of calls (poor coverage).
The State is also having to add a site up in Nassau County for the Ag. units at the weight stations.As a system manager of a local system said " the SLERS system can't even handle a house fire." :oops: :oops:
n4voxgill
Silent Key
New Braunfels, TX
this doesn't make sense. Macom told the state that they could get better coverage with less towers than were proposed for the motorola system.
Surely macom didn't tell a lie. After all, doesn't edacs go further than astro.
bravo14
Polk County FL
The FHP vhf does have poor coverage for this area. I use a out side attena and still comes in poor. I like to know what is the channels for the FLDOT police channels? I am not sure when St Johns is going to 800 yet. Does anyone know if Putnam FHP went to 800 yet?
LawDog
bad info
what your hearing is a vhf link for units working outside the macom coverage area in St Johns county. No vhf traffic in jacksonville. as soon as phase 2 goes live, the link will be taken down. the ag stations added a bi directional amplifier to increase portable coverage at their stations. Not weigh stations, they do not weigh vehicles, that would be motor carrier compliance DOT.
All state leo's are on the macom 800 and the old vhf systems for FHP are coming down and mobile are being removed. no more scanning state law enforcement, period.
http://sto.myflorida.com/slers/
wsmoore
Jacksonville,Fl.
St.Johns County is in Phase 4 (at least that is what the SLERS page says)so why the VHF patch?I though everybody in the State was 800 mhz now (Moto or MA/Comm).Can't they just go through the Sheriff's net patch on the motobridge system if the had to ?Does Jacksonville Area have this patch set up to?Shep
SOFA_KING
SE Florida
How can he hear "digital" or "talk groups" on the VHF link? The TGs he listed are from the current Motorola 800 system. He is listening to the Motorola system!
The real question is WHAT FREQUENCY IS THE CONTROL CHANNEL YOU ARE LISTENING TO ON? Assuming it's not a tropo band opening, it may actually be similar to the odd stuff I am hearing in St. Lucie County. A new MOTOROLA control channel came up and I hear some traffic separate from the main Motorola system. Perhaps this is a system designed for the AIR UNITS. The SOT mentions it will construct 10 special sites at selected areas of the state (all mentioned) just for the air units. They said air traffic causes interference on the ground because of it's greater range. The big mystery here is why they are using a Motorola system. Maybe that is part of the new plan. Much more will be coming in the near future with special Motorola links to facilitate interoperability from outside agencies who do NOT use EDACS. That is a know fact. How this will be done should be interesting!
fl-dj
Sunshine State
You can monitor any 800mhz digital encrypted call that is patched to VHF in the clear because the patch is made at the console after the call is decoded from digital / encrypted to clear analog voice for use at the console. Think of it this way, can your ear decode a digital / encryted voice call? NO, so you need a way for this to be decoded, once that is done and that audio is fed to the dispatch position, it can be patched to analog ANYmhz at will.
You can also setup a patch using 2 mobiles, take a VHF analog mobile and an 800mhz digital encrypted mobile and feed the audio out of one into the TX in of the other, there are kits that do this.
What you can't do (actually can but it doesn't work well) is patch a digital call to another digital call on a different system, example, 800mhz digital talkgroup to a vhf digital conventional channel. Will it work, yes but due to delays in vocoding and double vocoding the call will become un-useable.
This does not apply to a patch setup on a console with multiple digital talkgroups or channels within the same system.
SOFA_KING
SE Florida
FL_DJ,
I never mentioned anything about "encryption". What I pointed out was the fact that you can't get talkgroup ID's from a VHF conventional patch. I also said you couldn't hear "digital" on the VHF patch (meaning it's not a digital channel). I suppose you could if the VHF patch channel was also digital, but as you pointed out, two vocoder conversions would degrade audio quality.
bravo14, who lives near Jax, is seeing talkgroup ID's. He is saying they are digital channels. He must be trunking a system to get the TG IDs and it can't be Provoice digital channels if he is hearing it. I conclude he is listening (trunk tracking) to the State Motorola system. Band opening? Maybe he is in range of the Phase 2 system in Flagler.
As far as my interest in the future links out of the EDACS system, I just wonder how this will be done in terms of frequencies and access. I would bet the system would be one of those "don't call us, we'll call you" type systems with the SOF in full control of it. Maybe local level units who want to contact state units will have to request a patch from FDLE on either a patch frequency or on a call channel like MA CALL. I would bet that it will be a big deal to get a link established and might involve local dispatchers as well as state dispatchers to get it established. (introduce operator training issues and operator error here) If that does turn out to be the case, you could expect it to only be used for bigger emergencies or big joint ops. Most likely it would not be as easy as lets say a county SO unit picking up the mic and calling a state unit without major assistance.
All of this is speculation, so we will have to wait and see. If it does turn out to be true, I expect it will be a VERY limited resource. I see such "overcomplicated" "overcontrol" systems as major blockades to good interoperability communication. It's not easy, and operator error plus training issues are introduced which could be life threatening. With these types of systems being so complicated it would get little use, thus defeating the purpose.
I think the State of Florida is mismanaging it's communications. Poor choices all the way. It's bad enough that they intentionally "shroud" public communications on public frequencies with full encryption on everything, but to set up complicate solutions for interoperability with "big brother" overcontrol is not making an effective system for simple and easy to use interoperability. In short...I don't think they know what the hell they are doing.
What would have made better sense? A VHF statewide trunked system that brings every public safety agency in the state onto the system. That would be a good solution. Why VHF? Much better range for lower cost infrastructure (fewer towers needed), new "clear" frequencies that became available, and conventional channels with good range are also available (some of which are in use now). Now is the time to return to VHF (a much better band than 800 ever will be). Separate systems and frequency bands do not unify public safety workers. One good system for all on one good band is the solution. Proper talkgroup and channel assignment (programming) is also key to good effective communications. Build a simple easy to use system for all with excellent coverage (SIMPLE!). NOW IS THE TIME. Once the VHF frequencies become "eaten up", the State will not have the chance to get them.
No need for full time encryption on everything either! No one wants a police state! Anyone who has heard what is said on "Private Call" conversations on the State system knows what kind of abuses could be expected on fully encrypted systems. Without any type of "watchdog" from the public eye or press, we can expect abuse! This is not the "My Florida" I want to live in. It's becoming a dangerous policy of "secret government" with tones of over-control. If more of the public were scanner listeners, and they would write letters to our government officials in protest, we might be able to keep our rights to monitor public frequencies with public communications. The majority of Floridians are unaware of this dangerous policy of secrecy. The press has failed to make the public aware. We are losing a critical battle to protect ourselves from abuse.
Too bad we allowed the State of Florida to mess this all up so bad. We loose in so many ways. The STO has done a BAD job. We are screwed!
benjaminfs733
Nashville, TN
Could not agree with you more,
"Proper talkgroup and channel assignment (programming) is also key to good effective communications".
I have followed and used several different trunked systems in KY & OH. A selling point for building these systems is that all agencies can communicate but I have yet to see it happen very well. It was 5 years after a new 800 system was installed before any PD radios had any other agencies channels SO, Fire, or other channel in them (They still do not have the channels for the fire department). They could communicate before they got the system just fine, every one had UHF/VHF dual radios! Even now individual departments are always having to call dispatch and relay messages because no one monitors their own mutual aid channels. I agree with you 100%.
SOFA_KING
SE Florida
Roger that ~
Maybe someday they will figure it out. I do realize the radio equipment has limitations on how many channels you can setup on a "zone". That is usually limited to 16 channels, so you have to carefully plan what you need and then reserve a few for mutual aid. There is also a limitation on priority scan channels if you mix conventional channels in the same zone as trunked channels (TGs). You do have to think about those limitations and create multiple zones that have common elements along with a special purpose. Hopefully the manufactures will develop better ways to manage channels and scan lists in future offerings. Often times when radio operators switch zones, they get confused and lost. That is not good. The other problem is they loose touch with the main dispatch channels. From what I have seen of programming on a few systems I'm familiar with, there is a lot left to be desired. Keep main channels up front in all department zones and reserve mutual aid channels in the back channels. Stuff in between can be for special needs. I find that works best.
dhutsell
All FHP troopers still have the option of keeping a VHF radio for use when a system goes down and to monitor/talk to other agencies using VHF as many still do in FL.
fl-dj
Sunshine State
Ahhh, you might want to check that, part of the contract is for the removal and install of a radio per unit which translates to, take out the VHF and leave them with the new 800 mhz unit or in parts of the state, remove the 800mhz Motorola radio and replace with the MACom radio, also included is the removal of the mobile repeaters in places they are / were still in use.
Also makes no sense to keep the low band radio when the state has the channels shut down once they migrate users to 800mhz. Doesn't pay to maintain 2 infrastructures, especially when one is obsolete.
Seadoo
I agree with SOFA_KING. The state of florida does not know what the hell they are doing except waste money because all they had to do was complete the state wide motorola system and then bring all local law enforcement onboard being that most of the major countys were also running a motorola type II system and the rest could have had a patch over with vhf until they were ready to come online. This EDACS system was a waste of tax payers money.
