Retevis File conversion
Noah2
Ballarat
Hello I am not sure if this is the right place to ask but let me know if it is not and I will fix it but I just purchase the 180day premium and downloaded all the files for my area but they are csv files and I need them to be s rdt file for my scanner and I need help making them a rdt file thanks in advance Noah
fxdscon
¯\_(ツ)_/¯
What scanner do you have, and what programming software are you using?
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Welcome to the RR forums. You're a premium subscriber so you should be able to use a number of software programs depending on what scanner you are using to download info directly from the RR database to app then to your scanner without the need for CSV file conversion
dkcorlfla
Orlando
That's not a scanner. That's a two-way radio transceiver. If you believed you were buying a scanner, you were mislead.
Not only that but it's also a DMR transceiver. With a ham license they can be used with a local hotspot and talk all over the world. Can be quite a lot of fun but programing a DMR transceiver gets rather involved. If you are interested in ham radio I would say keep it otherwise there are much better choices for a portable scanner.
dkcorlfla
Orlando
Update - I just noticed that on the Retevis web site the current frequency range is 150-160MHz & 450-460MHz
Retevis seems willing to sell their products to countries with little concern over the legality of the frequencies. The range above is not l legal for ham operators in the US and I think Europe as well.
There is a good chance the transceiver can be (opened up) to work on other frequencies. I ran into this on my Retevis RT95. It was sold direct from Retevis to me in the US but it did not support the US frequencies. I was able to open it up to mode 2 and it works great and I love the radio but I can see this causing trouble. We really do not need people buying these transceivers and using them like a FSR transceiver.
Retevis offers great value on their transceivers but please be careful.
Hope this helps, Dale
dave3825
Suffolk County NY
If it's what the guys are speaking of in the previous posts, no, especially if it transmits. Exactly what make and model you have?
dave3825
Suffolk County NY
Definitely not a scanner. .
dkcorlfla
Orlando
But dose it still work like a scanner
It may well offer some scanning ability but most likely it will be slow, much harder to program and use, missing must haves like LO (temp lockout). Looks like it does have promiscuous function that may allow it to scan DMR but as I wrote in previous post DMR transceivers are complex to program.
