Finally,everything is covered!
Very nice setup! I have a phrase I use when people look at my garage and desk area and are a bit taken back by the "organized" nature of them. I say "God made most people perfect, but the rest of us have to be organized." That almost always breaks the ice.
I don't know what your experience has been pulling in 800 MHz from long distances over time. I have a 16 year old Diamond wide band vertical. omnidirectional antenna that has a preamp built right into the antenna, not an add-on that is installed inside the house. I pull in one 800 MHz repeater from 100 KM away. This is in terrain with a couple of 8100 plus passes in between, an assortment of lesser peaks, and a few other ridges. I use only LMR 400 RG-8 cable. Since the roof on my house can often be covered in snow for 6 or 7 months, and then exposed to the UV of 8,000 feet (2438 M) the remainder of the year, I begin to lose this repeater after a little less than three years, after which I have to replace the cable once again. For UHF/VHF reception the cable will last about 5 years.
I also have the same Diamond discone you have, but only use it when I'm visiting someone and staying at their house for more than a few days. You might say it is my "traveling antenna." Yes, it is a pain putting those endless radials on when I set it up each time. What do you use the multicoupler for?
tonsoffun
Senior Moderator
Central Ontario
The multicoupler is for the discone and is connected to the 2036 for the trunker and the other is for 1 bct-15 for most local stuff. A spare cable is there for when my 396 comes in the room.
The wilson is connected to my second bct-15 for 800mhz trunk systems and the LP beam is for the pro-2096 for VHF systems.
Take care
OpSec
All your WACN are belong to us
Monitoring the database
Very nice setup...looks great.
What are you using for a rack on those 3 scanners on the left side of your desk?
BJ_NORTON
Las Vegas
Just a thought, have you ever considered putting the feedline inside some electrical conduit? That way if would offer some protection from the elements, and you could paint it to match the house, or the roof? If I ever get a house, I think thats what I'll do. It should make the XYL a little happier, and that way I won't have to keep climbing up on the roof!
I hadn't thought of that before! I like your suggestion. I have plans to move my antennas to a different portion of the roof and electrical conduit would solve a number of problems, especially considering the number of cable hangers I would have to put in since I will be running three cables. It would really make it look professional. I will have to buy a conduit bender, but that isn't a major expense. There will be some sealing challenges which are inherent with having something lying under snow for many months, but some flexible caulking (so it can be removed when necessary) should take care of that.
Thanks again for the suggestion, that is the best new idea on radio I've gotten in quite some time.
