SDS100/SDS200: Finding ESN/SUB #
tonya
Bratenahl Ohio
I'm trying to purchase a DMR key for my SDS100. I've done this before with my 536 and 200 with no problem. I'd registered the scanner when I first bought over a year ago the serial # is showing on the left side of the registration page. In red letters I'm told the following:
* You MUST enter a valid ESN to be able to Purchase an Upgrade key.
Where is the ESN # located? I tried entering my serial # but its not letting me put in the last #. I read somewhere you get this off the box but that's long gone.
I also got the SN from scanner itself under Scanner Info in the menu. I replaced the 260 # with the letter Z but still can't put that last # in??
tvengr
Well Known Member
Baltimore County, MD
Press MENU (Lower half of button on left side of scanner} > Scroll to Settings > Press E > Scroll to See Scanner Information > Press E > Scroll to Firmware Version > Press E > ESN is on bottom line > Press AVOID to exit menus.
tonya
Bratenahl Ohio
Just figured it out. The first 5 numbers of the SN were already there grayed out above where the you put in the next 9 numbers then the 3 digit sub. Thanks tvengr for the response.
RMason
Mississippi / Colorado
That has tripped many people up. Glad you figured it out.
Mel19
Can anybody help me? Have the same problem, but my first 5 digits of ESN are not the same as the digits above.
Mel19
Maybe try this….
Thank you so much my friend!
On Australian site I bought key without problem and upgraded my SDS100E.
I hope this case will be help to someone else.
