Firestick Scanner Antenna......
bubbaearle
Has anyone here used this antenna?
I included a link to the info page........
I have an RS 20-032 which was a great unit until I had to replace the bottom coil......
Now the bottom coil is bending back (due to hot weather & wind at highway speeds). I wanna replace it with a unit that I can mount thru a hole in the roof of my van......previous owner had a CB antenna mounted.....very small base clean looking install.
Bubbaearle
http://www.firestik.com/Catalog/MSM-3&4.htm
Mobile Action Scan
Scanner Antenna
3 Foot Model MSM-3B: $18.99 (MSRP)*
4 Foot Model MSM-4B: $20.99 (MSRP)*
*MSRP (Manufactures Suggested Retail Price) in U.S. Dollars
High performance scanner antenna for cars, trucks, campers, motorcycles, boats, etc.. Receives police, rescue, fire, air and more. Efficient wire-wound fiberglass design with special built-in traps for better performance in the action-packed 140-170 MHz band. 25 MHz to 1200 MHz coverage. Double insulated copper wire and polyvinyl outer shrink covering greatly reduces static hissing and popping commonly associated with metal whip antennas.
Available in black only. The ferrule on this antenna has standard 3/8"-24 threads making it fully compatible with all Firestik mounts and accessories.
DSYCUTTER
Jackson, NJ 08527
I have one, mounted on my pick-up's bedrail. I get what I consider good reception, but I am only comparing it to a glass mount and the rubber duckies.
