Firmware
ABBAFATHER
ABBAFATHER
Does anyone know how to rollback, the firmware to version 2 instead of version 3 in the Uniden 396t?
UPMan
In Memoriam
Arlington, TX
Simply follow the original instructions to apply the update. No key is needed to revert to an earlier version. However, you cannot revert to a version prior to version 2.
UPMan
In Memoriam
Arlington, TX
Version 2 is no longer available from Uniden. Reversion is only possible if you still have a copy of the V2 firmware.
Why are you wanting to revert?
UPMan
In Memoriam
Arlington, TX
CC DND can easily be turned off.
While Scanning, press F+Hold repeatedly until the scanner displays CC OFF (or whichever other CC mode you want).
ABBAFATHER
ABBAFATHER
The only two in the radio meau is; CC DND and then CC PRI. In version 2 had interruptions, but CC was active when someone was talking. Now in version 3 CC does not work while someone is talking. Correct me if am wrong please.
UPMan
In Memoriam
Arlington, TX
For CC all we did was add a mode (CC DND). We didn't take away any modes. If you prefer the CC to be active during other reception, then set the scanner to CC PRI.
