HP-2: Firmware
jcarpenter2
Battletown (Meade County), KY
Does anyone know the firmware version the HP2 is on? My HP2 reflects 1.05 and the Sentinal version is 2.03 version 5.
When my HP2 is connected to the computer with the Sentinal software running it reflects the firmware is correct. Can anyone confirm that?
W8RMH
Feed Provider Since 2012
My HP-II firmware is 1.05.
My Sentinel is Version 2.03 (revision 02).
The HP website states "The latest version of Sentinel is version 2.03, released on November 10, 2014. Version 2.03.02 adds support for the HomePatrol-2."
I don't see any version 5 anywhere.
jcarpenter2
When i select the "about" in Sentinal is shows Version 2.03 (revision 5).
I looked high and low in unidens site but find very little about the HP-II and definitely don't find the firmware for the HP-II, though i do find comments about the HP-I which says to ensure your firmware is 2.02 or higher, hence why i was wondering about the firmware for the HP-II.
Thanks for the response.
Voyager
My HP-2:
Main FW version: 1.05
Sub FW version: 1.02
Sentinel version: 2.03 (revision 02)
You never said what your sub version is, but it appears your scanner is using the latest firmware. If you are asking why Sentinel is 2.03 when the scanner is 1.05, keep in mind they are two different products and the version will almost never be the same for both.
W8RMH
I was under the impression that the HP-I and HP-II are the same scanner except for how the batteries are charged and that the HP-II will decode Phase II.
Voyager
The HP-1 and HP-2 are different products and will have different firmware revisions (odds are the HP-1 will always be higher since it's been out longer). you cannot mix-n-match firmware between the two just as you cannot mix-n-match firmware between any different Uniden models. You won't find any firmware updates for the HP-2 because none have been released yet.
jcarpenter2
Here is a screenshot of my sentinal software with firmware 2.03 and (revision 5) showing. Unless im looking at the wrong thing?
As for the HP-II firmware, i do understand what you all are saying, i just couldn't find anyware "official", like the uniden site, showing what the current firmware for the HP-II should be.
cpfinlay
Philadelphia, PA
That is the version for your software (Sentinel).
To see the firmware version installed on your HP-2:
- On the HP-2 itself, select Menu
- Advanced Menu
- Down arrow
- Version information
Voyager
I would delete and reload Sentinel from the website. That may be a test version that was posted to address a PC file system error that removes the safeguards that prevent accidental erasure of the C drive. If it is, you REALLY don't want to be using that. It was never posted as a regular release.
