First time SDR operator (please help!) (RTL-SDR v4)
CrowsSDR
Hello fellow radio enthusiasts!
I am very new into the SDR scene, having started out with an RTL-SDR v4, and a simple dipole antenna. Thus far, I have tried using GQRX on my laptop running antiX 32 bit (a Debian 12 derivative).
I got reception, but known frequencies were way different from what it took to find them on gqrx. For example, to find the FM radio station at 99.1, you would have to tune to 54.5.
I noticed when I followed the instructions to purge the old drivers for the v4, that my system also removed gqrx along with it. I'm suspecting that when I subsequently reinstalled gqrx, it "undid" the work I did for swapping the drivers.
Is my problem most likely caused by the 32-bit version of gqrx being behind in support? I have yet to try 64-bit OS, but I did do a clean install of antiX 64-bit the other night in preparation for my next run.
Or is there something else I am overlooking?
dave3825
Suffolk County NY
Sounds like something is misconfigured. Post some screenshots of gqrx showing settings.
CrowsSDR
I will try to get it up and running on the new 64-bit install, then get some screenshots.
Pretty sure I had an error message when I was reinstalling the custom drivers for the v4, that I didn't get when setting up on the old 32-bit install, so I'm skeptical. I'll get details on that too when I reattempt.
Thank you for the response!
CrowsSDR
Update:
Well. I fired up GQRX in the new 64 bit install.
I'm not sure what I did differently this time, other than adjust the ppm compensation, but it seems to work great now. Don't really wanna go back to the 32 bit OS to test it again lol.
CrowsSDR
Any advice on my configuration settings?
Again I'm very fresh to SDR software, and this is the first time I've really put any effort into a radio setup.
