Fleetnet Settings For 396T
EJB
20 + year membership
Downtown Hamilton
Hullo.
I recently was given a 396T from a friend. I used to own one at one time but its been almost 8 years since I used it. For those who love baseball, the day I sold it was when Roy Halliday threw a no hitter in the playoffs for the Phillies. But back to my question.
For Fleetnet, What are the proper settings? I am often hearing the annoying digital crunching sound at the beginning of transmissions from the digital users on the system.
STATUS Bit-Yes or Ignore?
SET END CODE-Yes or Ignore?
Digital End Code-Yes or Ignore?
Its amazing to see and hear how far we have come with scanners. I first got a 396T back in 2007. And it was state of the art. I have owned a 396XT, a PSR800, GRE500, and Home Patrols. I can't remember how to set up the above questions.
I appreciate any response.
Thank you.
Eric
wtp
Port Charlotte FL
i also sent a personal message
STATUS Bit-YES
SET END CODE-Yes
and they are set the right way as default.
gary123
I would use the stuts bit ignore that way the scanner isnt trying to decode numerous TGs for one user.
I use a 396 for CC its small and easy to keep in a pocket.
gary123
here are my settings from ARC396
system type = motorola type2 VHF
Channel delay = 1 sec
system hold time = 1 sec
APCO25 threshold = manual 8
trunk system parameters
scan mode = Id scan mode
icall = on
mode = FM
end code = yes
digital end code = yes
status bit = no
control only = no
141.015/15.0/380
151.730/15.0/579
154.320/15.0/632
Trunk freq are for the local tower I want to scan. the same for TGs. The TG values are the ones from the bellfleetnet wiki page (no editing is required).
Forts
Ontario, Canada
Hullo.
From what I recall the 'T' was bad for motorboating at the start of some transmissions. This was improved a fair bit when the 'XT' came out, along with better volume balance across analog and digital channels.
Always liked the T/XT series.... very nice little units.
gary123
Battery life could also be better but for a small compact scanner its great.
If I had a wish list I would love to have a choice of changing it from P25 to DMR or NXDN format. I know the scanner would only be able to support the one mode but it would breath new life into some of the older hardware.
