Flightaware and airband running on Pi 3B+
dkcorlfla
Orlando
Amazing post, thanks for sharing.
can you share your hardware that you used ?
which usb sound card, fan, heatsink, RPi case and link if it is not a problem ;)
I will try to put something together. Been busy on a DIY kitchen re-model.
dkcorlfla
Orlando
Here is a list of the items used to build the system. All bought on Amazon. A copy and paste into the search box on Amazon should pull the items up.
SaiTech IT 4 Pack 15cm Short USB 3.0 Male A to Female A Extension Cable $11.99
Extension cables used to add clearance so 2 USB dongles can be used on the Raspberry Pi (has tight spacing on the four USB ports)
Wathai 2PCS 50mm x 10mm 5V Mini Box USB Computer Fan with 3 Speed Control $10.99 (pair) (Nice quite oversize fan to keep things cool)
[5V 3A 15W] iUniker Raspberry Pi 3 Case, Power Supply With Switch for Pi 3 B+ $13.99 (nice case but comes with a tiny fan with a high pitch whine that did not cool enough when running the Pi hard)
YWBL-WH External USB Audio Card Driver USB Sound Card External Audio CM108 $7.92 (nice USB sound card with excellent audio playback and a mic input)
The heat sinks used came as part of the case above.
The audio is really good on this system, I also complied and run NRSC5 to play digital broadcast FM on this system.
Hope this helps
ramimz
Key largo, Florida
Hope this helps
Wow. Thank you very much for the detail answer.
I hope I won't have any trouble setting everything up ;)
dkcorlfla
Orlando
If you do have trouble let me know as I have the history and notes from the compile and install.
