Floating radio station
todd103
So I have a sailboat with a 30 foot mast, at the top is a standard VHF antenna for the boat radio. Theoretically would it be possible to broadcast a standard FM radio station using this antenna that would be audible on shore if I was a mile off shore? Would this be able to run off a standard 12V deep cycle? (Not saying I would do this, just wondering about the mathematics behind it and the kind of quality listeners would get).
cabletech
Puget Sound
As the bost antenna is tuned for the 150mhz marine band, not the antenna will not work for normal FM radio broadcast.
Also, in order to broadcast you will need a license from the FCC and they would not allow it on a boat.
Looks like CableTech was typing too fast...
No, the antenna on top of your mast is likely a half wave VHF antenna designed to be resonate in the high 150 to low 160MHz range, so it would not be a good antenna for the FM broadcast band. It might radiate some, but your SWR will likely be pretty high.
Those antennas are usually fed with pretty lightweight RG-58 cable, and it won't carry a whole lot of power, and what power you do put into it will be mostly lost along the cable path. Even with a properly resonate antenna, you'd probably loose 50% or more of your signal to cable losses.
Theoretically speaking, yes, a small FM transmitter could be run from a boat with 12 volts. You would need a properly tuned antenna and would want to use much better coaxial cable.
As CableTech said, you would need an FCC license, because at only 1 mile off shore, you are still within the United States, and the FCC has authority. I can't remember the exact distance you need to be offshore to be outside the US. I want to say 12 miles, but I could be totally wrong. At 12 miles, you are not going to cover very much dry land with a 30 foot tall antenna.
But, yeah, sure, it could be done. Not legally, but it could be done. Personally I think AM broadcast would be better, you have an excellent salt water ground plane, and you have a tall enough support to put up a loaded or base tuned wire antenna.
