Florida SLERS (EDACS and P25 00A.92463)
lwvmobile
DSD-FME
Lafayette County, FL
This might be a bit of an odd question, or one not being asked in the right place, but as far as SLERS Edacs and the band its on 851-860, or whichever it is precisely, how do you determine what the stepping is for each LCN channel? As in, if I look at a channel that is 851.3725 Mhz in an SDR application, but my PPM is slightly off, how do I say, okay, that should really be 851.375Mhz because the band plan and system directly specifies that.
If anybody is wondering, I'm working on an SDR application that will scan through the band to attempt to lock onto SLERS Edacs control channels, but just scanning the band outright had me landing on the edge of frequencies instead of dead center, so I'd like to know if anybody can enlighten me as to what the proper stepping is so I can say land on channel x, nothing here, step forward 12.5 Khz or whatever it is, or say, go to the next valid channel, instead of doing a sweep every 5k or whatever.
GTR8000
NY/NJ Database Guy
BEE00
There is no standard band plan for EDACS systems. Any frequency can be assigned to any LCN. It's more or less a free for all in that you license whatever frequencies you can for a site, and assign them each to a unique LCN, and off you go.
bravo14
Polk County FL
A month ago when I was traveling east bound and I was using Unitrunker v2 and noticed the peer section and found each site has site neighbors list.
bravo14
Polk County FL
Wakulla County Sopchoppy Site 231. NL 1, 5, 56, 82, 114, 115, 198, 232, 255 (not sure if 1 5 255 is a glitch or there is sites somewhere that is hidden or back up?)
lwvmobile
DSD-FME
You should make one of those mesh net maps, where you have each site pinned on the State of Florida, and a line drawn from each site to each PEER site. Sounds like it'd be right up your alley.
lwvmobile
DSD-FME
Anybody notice any strange activity on SLERS EDACS sites lately? The past couple of days, I've noticed a few irregularities, and today, I am on Site 177, Control Channel is on LCN 3, yet ESK mode seems to have been disabled (Commands come in as FC/FD/FE/B8 and not the XOR equivalent, and the site isn't relaying a proper Site ID or any patches, or atleast not a Site ID I'm accustomed to seeing. I have had one call occur since this irregularity started this afternoon. I've flipped the XOR off on my software for ESK, and still get proper group calls I'm used to seeing. I've also tried using EDACS standard/networked rules and get nada and an unsteady Site ID so I'm sure that isn't the issue.
lwvmobile
DSD-FME
Well, nevermind, figured out the Site ID, but ESK mode is currently disabled on Site 177 for unknown reasons. Had my software hardset to look for command 5D instead of the command ^ 0xA0. But still, strange for ESK to be disabled.
You can see on the FR_1, the leading F is a dead give away that ESK is off, if its on, it always reads as 5 for most CC information commands.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
one of the aspects of the hobby I really enjoy is finding and analyzing systems...
except SLERS.
I get no enjoyment out of anything having to do with this system....
d
lwvmobile
DSD-FME
Just when I thought I had it all figured it, it went and threw me for a loop, using Extended Addressing without ESK. Going to have to change a few of the hard coded things in my software now to account for XOR off or XOR on. I still find it enjoyable to analyze, just kind of boring since its 99% encrypted voice.
lwvmobile
DSD-FME
Late last night, I observed the same thing happen on Site 181 Tennille, ESK was turned off. I'm not super familiar with how the actual radios work themselves, but maybe somebody knows. If ESK if employed, and you turn it off, won't that keep pretty much any radio on the system from being able to lock onto that site control channel? Or can the handhelds be programmed to use Extended Addressing with or without ESK, and perhaps a signal comes from the CC that can instruct the radio to use or not use it. I was under the impression that ESK was used more as a way to keep older units that couldn't do Extended Addressing from being able to lock onto a control site since the data stream is modified from original EDACS. Keep in mind, the control channel was still using Extended Addressing, just the two bits weren't flipped for some reason.
This morning, Site 177 seems to have restored ESK once more. While I only realized it last night, I believe I observed this same thing happen for the past three nights where I couldn't get a proper signal ID, but only thought it was a distant signal. When poking into it, I realized that ESK was off, and was able to change a few parameters to get the Site ID, Peers, Patches, and Calling restored and everything looked fine when I made an option to flip ESK on and off in my software.
captainmax1
Florida Keys
Have you actually heard chatter on either SLERS systems lately? I haven't heard chatter in South Florida on SLERS in a long time. And yes, I know they are E but sometimes would still hear chatter in the clear. Same for Border Patrol. They use to switch it on and off but haven't heard any action on this lately either.
lwvmobile
DSD-FME
Oh yeah, I get chatter all the time. Most of it is from FHP groups, but there are some local groups as well. Most everything is capital E, but there are a few D. I can pick up 22049 and 22065 Taylor County Talkgroups that aren't encrypted, but they belong a site or two over from me, but sometimes they come in on Site 243, Site 229, and Site 177 and I can listen in, but only if the wind is blowing the right direction.
Here's a little quick demo of what's going on in my area. Wasn't very busy when I captured this, and its all encrypted. More of a demo than anything else.
lwvmobile
DSD-FME
When the bands open up, I can use SDR++ and EDACS-FM to surf the band, watch activity, and collect information on sites I'm picking up on a given morning. This is what I was able to get this morning.
lwvmobile
DSD-FME
Spending Friday evening listening to radio technicians going nuts on SLERS, followed by the insanely ridiculous and incredibly stupid triple channel decoding. Why monitor just one SLERS site, when you can watch three at the same time :whistle:
bravo14
Polk County FL
Wonder what channel 1-4 were? Wonder where on 23rd St he was at he wasn't too far from the house from me.
lwvmobile
DSD-FME
Pretty sure when they were doing the channel checks, they were doing them on each site individually. I was monitoring Site 177 and Site 243, and they did channel checks on both of them at different times, and skipped right over the correct LCN for the control channel on both. The stuff later on, with the fire mode and the TTA passing, that's what I want to know what that means. There was even more chatter, but some of it was pretty bad decoding, especially the stuff on Site 177, it was really hard to make out, especially when it got dark outside. When I heard some of the other chatter with them driving around testing stuff, I honestly thought they were local here, but when I heard them in PCB I wasn't expecting to hear that. If you had your scanner on, you could have driven around looking for them :ROFLMAO:
bravo14
Polk County FL
I need to throw the radio on and see what I get. I'm not sure if they are doing testing now since it is 10:40pm. I heard TTA Passing from the YT. I'm not sure what that is either. My luck if I drive around find them they would take off in a space ship :ROFLMAO::ROFLMAO:
lwvmobile
DSD-FME
From the best I can tell, they seem to run their tests once a month on a day towards the end of the month. I mentioned in an earlier post that they were active on Oct 29 doing the same channel checks, and here are the logs I got of them yesterday. I'm glad nobody called me out for calling it a 'Friday Evening' when it was in fact, on a Wednesday. They seemed to be going randomly from about 2:30 PM to 9 PM on Site 243, and I didn't start up 177 until around 6PM, so I don't know if they were active on there earlier or not.
2021-12-22 14:32:33 SITE 243 LCN 1 TG 49962 RID 131583 Digital
2021-12-22 14:32:42 SITE 243 LCN 3 TG 49962 RID 131583 Digital
2021-12-22 14:32:50 SITE 243 LCN 4 TG 49962 RID 263166 Digital
2021-12-22 14:33:01 SITE 243 LCN 1 TG 49962 RID 197614 Digital
2021-12-22 14:33:09 SITE 243 LCN 3 TG 49962 RID 197614 Digital
2021-12-22 14:33:18 SITE 243 LCN 4 TG 49962 RID 197614 Digital
2021-12-22 17:09:00 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 17:09:03 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 17:09:08 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 17:09:11 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:01:52 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:01:55 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:01:58 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:28:52 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:28:54 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:28:57 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:45:36 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:45:40 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:45:44 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:45:49 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:45:52 SITE 243 LCN 4 TG 49962 RID 263205 Digital
2021-12-22 18:45:57 SITE 243 LCN 1 TG 49962 RID 263205 Digital
2021-12-22 18:46:01 SITE 243 LCN 3 TG 49962 RID 263205 Digital
2021-12-22 18:46:06 SITE 243 LCN 4 TG 49962 RID 263205 Digital
2021-12-22 19:10:00 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:10:04 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:10:06 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:10:08 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:10:15 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:10:16 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:10:20 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:10:21 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:10:25 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:10:29 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:10:32 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:10:36 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:10:41 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:14:01 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:14:11 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:14:16 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:14:24 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 19:14:27 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:14:41 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:14:49 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:15:23 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:15:54 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:22:11 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:30:11 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:30:38 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:30:45 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:30:47 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:30:52 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:31:16 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:31:24 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:31:35 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:31:49 SITE 243 LCN 1 TG 49962 RID 131603 Digital
2021-12-22 19:31:53 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:32:00 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:40:25 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:48:29 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:48:33 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:48:40 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:50:06 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:01:39 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:01:43 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:01:45 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:02:02 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:04:11 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:04:13 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:04:14 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:04:14 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:04:19 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:05:00 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:05:01 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:05:03 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:05:07 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:05:51 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:05:51 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:05:53 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:05:56 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:07:08 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:07:09 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:07:10 SITE 243 LCN 1 TG 49962 RID 131614 Digital
2021-12-22 20:07:16 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:09:06 SITE 243 LCN 3 TG 49962 RID 131614 Digital
2021-12-22 20:09:07 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:09:09 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:09:10 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:09:11 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:20:37 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:20:46 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:20:56 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:20:59 SITE 243 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:21:02 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:21:07 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:21:12 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:21:15 SITE 243 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:21:20 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:21:40 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:21:54 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:22:00 SITE 243 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:22:05 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:22:17 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:23:28 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:35:19 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:35:26 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:35:29 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:35:34 SITE 243 LCN 3 TG 49962 RID 131603 Digital
2021-12-22 20:35:50 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:35:54 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:36:00 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:36:09 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:36:14 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:36:17 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:36:33 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:44:56 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:45:03 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:24 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:28 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:53:33 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:53:38 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:44 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:53:47 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:48 SITE 243 LCN 3 TG 49962 RID 131603 Digital
2021-12-22 20:53:50 SITE 243 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:51 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:53:52 SITE 243 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:53:54 SITE 243 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:55:54 SITE 243 LCN 3 TG 49962 RID 263207 Digital
lwvmobile
DSD-FME
2021-12-22 17:59:53 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 17:59:58 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:00:00 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:26:54 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:26:56 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:26:59 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:43:38 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:43:42 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 18:43:46 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 18:43:50 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 18:43:54 SITE 177 LCN 3 TG 49962 RID 263205 Digital
2021-12-22 18:43:59 SITE 177 LCN 4 TG 49962 RID 263205 Digital
2021-12-22 18:44:03 SITE 177 LCN 1 TG 49962 RID 263205 Digital
2021-12-22 18:44:08 SITE 177 LCN 3 TG 49962 RID 263205 Digital
2021-12-22 19:08:02 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:08:06 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:08:08 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:08:10 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:08:16 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:08:18 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:08:22 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:08:23 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:08:31 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:08:34 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:08:37 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:08:43 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:12:03 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:12:15 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:12:16 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:12:18 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:12:26 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:12:30 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:12:40 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:12:53 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:13:26 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:13:56 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:20:15 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:28:13 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:28:40 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:28:47 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:28:49 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:28:54 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:29:17 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:29:26 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 19:29:37 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:29:50 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 19:29:55 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:30:02 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:38:29 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:46:31 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 19:46:35 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 19:46:41 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:48:08 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 19:59:40 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 19:59:45 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 19:59:47 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:00:04 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:02:13 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:02:15 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:02:16 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:02:17 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:02:20 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:03:02 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:03:03 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:03:05 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:03:10 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:03:52 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:03:53 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:03:55 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:03:58 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:05:10 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:05:11 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:05:12 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:05:18 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:07:07 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:07:09 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:07:10 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:07:12 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:07:13 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:18:39 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:18:48 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:18:57 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:19:01 SITE 177 LCN 3 TG 49962 RID 263229 Digital
2021-12-22 20:19:04 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:19:09 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:19:15 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:19:17 SITE 177 LCN 4 TG 49962 RID 263229 Digital
2021-12-22 20:19:22 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:19:42 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:19:56 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:20:03 SITE 177 LCN 1 TG 49962 RID 263229 Digital
2021-12-22 20:20:06 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:20:19 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:21:30 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:33:21 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:33:28 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:33:31 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:33:35 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:33:52 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:33:56 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:34:01 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:34:13 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:34:16 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:34:19 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:34:35 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:42:59 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:43:05 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:51:27 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:51:30 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:51:37 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:51:39 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:51:46 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:51:49 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:51:51 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:51:52 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:51:54 SITE 177 LCN 3 TG 49962 RID 263207 Digital
2021-12-22 20:51:55 SITE 177 LCN 4 TG 49962 RID 263207 Digital
2021-12-22 20:51:56 SITE 177 LCN 1 TG 49962 RID 263207 Digital
2021-12-22 20:53:56 SITE 177 LCN 4 TG 49962 RID 263207 Digital
